20 Most Recent
Liquid Video E15LCD1 15" Questions & Answers
Hi, suddenly my LiquidVideo flatscreen
If the image is like that it's usually because one of the channels from the signal cable is interrupted. But since this model E15LCD1 is a very simple monitor without any extra capabilities and the only signal connector is a VGA that means that the cable either it isn't plugged correctly or it has failed and must be replaced.
I just reloade Windows XP Home and my E15LCD1 get out of range
when the computer turns on , keep pressing f8 or f12 to give u a boot options, choose safe mode. when windows xp loads up right click on desktop and goto properties, then click settings, then addvance, then click on the monitor tab, and lower the screen refresh rate down to its lowest and then restart pc. hope this helps. if u cant change these options in safe mode use a normal monitor and lower them down to 60 hertz and then put back in your lcd. hope this helps.
No sound from my new monitor
just check the problem area
first go to sound setting by click on sond icon on task bar and set the speaker on.
if not get possitive result then chech sond by using head phone make sure sound drivers working properly or not if not then reinstall the sound driver
Monitor reads "out of Range"
With another monitor attached to your computer, right click anywhere on the desk top. Click on properties. Select the Settings tab. change the settings to 800 x 600 with a refresh rate of 60 hertz. Now attach the Liquid Video TV.
I beleive that 800 x 600 is the maximum screen resolution that this TV / monitor can support.
Monitor won't stay on
Restart the computer and tap on f8 button so u can start computer in safe mode, if u are able to restore computer to earlier tiem. IF u are unable to start using safe mode. Ur computer need to reformat. Please insert recovery disc restart computer and tab on down arrow button and follow onscreen instruction...
No sound from the monitor
Plug the monitor speakers into a source of constant sound (mp3/cd player) and make sure the monitor is not muted and volume is at least half way.
If that works adjust the volume and mute settings on the computer
No Signal
You have to use the FN key and F5 to change between the LCD screen and the external monitor. It may be F8 also, depending on the laptop model.
Look on the F keys for a little picture of a monitor.
Once you have found it, hold the FN key and tap the F key and it should switch to the external monitor.
Liquid Video monitor - no sound
I have no solutions, but I'd love to hear from someone who knows what to do...I have the same problem...only my speakers on my monitor USED to work. I moved and now that I've set it back up, there's no volume. I wonder if I am missing some kind of audio wire and if so, where I can get it from.
