20 Most Recent LG Studioworks 440SI 14" CRT Monitor Questions & Answers
0answers
Monitor is not showing the display after booting.
Hello!
Yes you have change the settings of your display to a higher resolution and your monitor is not compatible with that setting, to fix this you can bring your system unit to a friend or neighbor who has a computer and try changing it if your friends monitor is capable or compatible with your display settings. Or if you have other monitor you can swap it.
Hope I was able to help.
7/30/2010 11:37:56 AM • LG Studioworks... • Answered on Jul 30, 2010
LG 440SI CRT
What is the problem with your monitor? i would appreciate if you can give detail information on the problem, so that i can advice on it.
Take care.
7/18/2010 8:39:53 PM • LG Studioworks... • Answered on Jul 18, 2010
When i start up my computer it says on the monitor
when You start the monitor please press F8 button of keyboard upto dos screen come and select a option that Enable VGA Mode and press Enter.Might be problem will resolve.login through administrator and set the display setting as 1024*768 .If again problem comes that out of frequency ,then restart the system and press F8 and Enable VGA Mode and login and re-install the Graphics driver again.If issue not resolved then problem with VGA port in CPU or VGA Cable not supporting gt it replaced.
11/14/2009 2:52:44 PM • LG Studioworks... • Answered on Nov 14, 2009
Out of frequency problem with dead screen on startup
60hz
8/30/2009 5:51:48 AM • LG Studioworks... • Answered on Aug 30, 2009
Not working 1024 by 768 pixels resolution
reduce the number of colors until you can get a resolution that works the monitor cant handle the number of colors and the number of lines of resolution this is a common problem with older monitors.
l8r
2/18/2009 7:40:40 AM • LG Studioworks... • Answered on Feb 18, 2009
Power supply get dropped
what power supply do you mean Sir/Ma'am.
is it the AVR (automatic voltar regulator)?
if its the AVR, just switch it on and check the output voltage with a multimeter (AC range 250)
you should see the voltage output nearly equal to your SERVICE AC voltage
11/6/2008 4:29:14 AM • LG Studioworks... • Answered on Nov 06, 2008
Monitor problem
Your request for the exact problem will require a signal injector and use of an oscilloscope or even more test equipment. One possible cause is the contrast set to minimum.
10/12/2008 4:12:17 AM • LG Studioworks... • Answered on Oct 12, 2008
Monitor not working
ya 6n60
8/16/2008 2:51:47 AM • LG Studioworks... • Answered on Aug 16, 2008
What is the angle of polarized flim for LG Flatron E2240T?
See troubleshooting section of user manual on page 25 for help. https://gscs-b2c.lge.com/downloadFile?fileId=KROWM000342803.pdf For further help you can use this page LG E2240T-PN: Support, Manuals, Warranty & More ' LG India Support
1/7/2024 11:28:15 AM • LG Computers &... • Answered on Jan 07, 2024
What normally burns out the LG Hi-Fi Amplifier?
Full 'make model (what it is)' in all questions please, first 3 words. Capacitors can split or bulge, resistors can burn,, the transformer can fail internally.. Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
12/22/2023 2:12:49 AM • LG Computers &... • Answered on Dec 22, 2023
What does 9 red flashes mean on LG multi V LMU540HV
A communication error has occurred between the outdoor and indoor units. Faulty wiring or a malfunctioning control unit may be responsible. Contact LG customer service for assistance. Their number is 1 800 243 0000.
10/22/2023 4:35:12 PM • LG Computers &... • Answered on Oct 22, 2023
My LG solar dome displaying F10 what can I do
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit
10/10/2023 5:01:07 PM • LG Computers &... • Answered on Oct 10, 2023
How do i take out the entire stand on my monitor so I can wall mount it
here is a link to unstructions copy and paste https://www.manualslib.com/manual/243281/Lg-W2043t.html#manual
8/17/2023 6:33:04 PM • LG Computers &... • Answered on Aug 17, 2023
LG Studioworks 440SI 14" CRT Monitor Logo
20 questions posted
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Studioworks LG
  • Studioworks LG
Most Popular Question
monitor not showing display after
  • Computers & Internet
