20 Most Recent LG Studioworks 775N 17" CRT Monitor Questions & Answers
Hi, i have LG Studioworks
Bad solder connection on CRT circuit board resolder all bad connectios
4/25/2017 12:50:20 AM • LG Studioworks... • Answered on Apr 25, 2017
Why is my display blurry?
I had a blurry screen last week and too it to IT support. They were able to play around with my software and repair the computer from some of the glitches and viruses that it had. Have you tried getting professional help with your issue? Managed IT Services from InfinIT Consulting
8/28/2015 1:05:17 PM • LG Studioworks... • Answered on Aug 28, 2015
My LG 500G CRT 14inch monitor become rotate from
Hi there monitor rotated or the Menu/ program file are going on top side? Please let me know that, also tell me which operating system you use.
2/1/2011 11:31:34 AM • LG Studioworks... • Answered on Feb 01, 2011
2answers
MY LG 500G CRT 14
open the monitor there is a movable preset attached to EHT rotate that preset by screwdriver in active on condition of monitor reduce the brightness to satisfactory level
9/13/2010 12:36:56 PM • LG Studioworks... • Answered on Sep 13, 2010
Im using an lg studioworks 755e monitor and it's
Thank you for your question.
Fixya has many manuals online to view and download to assist in problem solving.
Your manual is at the link provided.
http://www.fixya.com/support/p397663-lg_studioworks_775n_white_17_crt
I would suggest you download it, it is a small file of 2Kb and on page A11 you will see that you need to turn on the "degauss" function. This is essential on CRT Monitors.
Also another idea is to ensure that you don't have speakers placed too close to the CRT Monitor, they will "mess" with you display, if this is the case, move the speakers away from the monitor to correct this situation.
Hope this works for you.
Kind regards
4/28/2010 12:42:20 AM • LG Studioworks... • Answered on Apr 28, 2010
I conneccted my new pc with windows7 to LG 775N
If you have the posibility try to connect to another monitor and then set the rezolution to minimum (800 x 640 or 1024 x 768) and set the frequency to minimum also (about 60 or 72) and then after the shutdown connect the LG monitor. If all it's ok try to resize to maximum refresh rate (for 1024 x 768 is 85 Hz or for 1280 x 1024 is 60 Hz).
If you don't have any other monitor try to enter in Safe Mode (press F8 key before entering in operating system). After that right click on my computer icon from desktop or from Start Menu and from the Management, Device Manager - Display Adapter right click on video adapter name and choose uninstall and then restart. After restart windows should detect again the card and the monitor.
4/9/2010 10:40:54 PM • LG Studioworks... • Answered on Apr 09, 2010
The OSD and SET buttons on my monitor are not
I used to work at a company that specializes in CRT and LCD refurbishing. If a CRT's buttons have gone bad theres nothing you can do other than having them physically repaired.
1/24/2010 8:02:45 AM • LG Studioworks... • Answered on Jan 24, 2010
My lg 14 inch crt desktop monitor pictue become
The CRT has screen adjustments, there is a screen adjustment button on the monitor that will allow you to adjust the width of the image as well as the height etc.
1/21/2010 8:15:34 AM • LG Studioworks... • Answered on Jan 21, 2010
Black then gradually disappear in crt mointor
This problem needs a professional service technician,the problem could be on the picture tube/CRT or the ply back.
9/14/2009 12:26:31 PM • LG Studioworks... • Answered on Sep 14, 2009
Hi need some help with 17
You can try starting your computer in safe mode and restore your computer to another safe point. usually this problem is caused by an update or a new driver installation/update...
8/11/2009 5:04:03 AM • LG Studioworks... • Answered on Aug 11, 2009
I have a similar problem, please let me know if you have the fix
Hello
This is RGB issues the problem is in the CRT Board where the RGB is, this need to re solder the RGB board or CRT Board maybe you have cold solder...
Angel
Thanks...
8/2/2009 3:45:59 AM • LG Studioworks... • Answered on Aug 02, 2009
ı need cable color to pinout?
YOUR DATA CABLE IS 14PIN CPU SIDE,
11/13/2008 5:58:34 PM • LG Studioworks... • Answered on Nov 13, 2008
EHT FAILURE
YOUR LG 17" MONITOR S.W 775N EHT NO ( 6174Z-1012B )
( AE28JJ )
11/13/2008 5:53:27 PM • LG Studioworks... • Answered on Nov 13, 2008
3answers
Horizontal display
Check with the manufacturer information that you have the refresh rates and maximum resolution set correctly. If in doubt, go to your display properties and try something basic to test if this is the problem. A basic setting may be as low as 1024x768 at 60 Hz.
(You can access your display settings by right-click the desktop anywhere and choose properties, then settings).
Leave the monitor at that setting for a while to see if the monitor changes the picture.
If the picture changes, it may be component failure in the monitor. If not, the problem is then related to the settings from your VGA card are too high or dense causing the monitor to fail after a time. Try something higher like 1280x1024 @ 60Hz and keep going till the picture fails. Compare the best functioning resolution with the manufacturer claims about the product in the product documentation.
Be sure there are no cable bunches and the power cables are not wrapped up with the VGA cable under the desk or there are not too many cables lying about, although unlikely, this has been known to distort the picture.
Let us know if this helps.
Cheers
Gund
9/6/2008 12:46:00 PM • LG Studioworks... • Answered on Sep 06, 2008
Dynamic focus
firstly switch off your monitor
12/27/2007 9:58:17 AM • LG Studioworks... • Answered on Dec 27, 2007
Blurred Corners
hi there, its a decousing problem, look for the connection of the decousing which is connected behined the pic tube to the board. check some electronic parts, it may be temperature resistor, termistor, transistors, capacitor, etc.ty
12/25/2007 3:48:21 PM • LG Studioworks... • Answered on Dec 25, 2007
Screen Replacement part L05N
http://www.eserviceinfo.com/downloadsm/1099/_775N-CB775BN.html
go through the given web site download it.
 this will give you the circuit diagram of your monitor.
you can find out the value.
please do not start working unless aware of it.
as monitor has high voltage inside.
LO5N  WILL BE COIL.
AS  L  means coil.
C means capacitor.
good luck.
10/11/2007 10:52:41 AM • LG Studioworks... • Answered on Oct 11, 2007
LG Studioworks 775N 17" CRT Monitor Logo
30 questions posted
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Studioworks LG
  • Studioworks LG
Most Popular Question
black gradually disappear in crt mointor
  • Computers & Internet
