20 Most Recent Blue Wave NFC0131 4-5/8 x 9-3/4 tsc filter cart Questions & Answers
Does a cartridge filter need to be backwashed?
No. Cartridges are cleaned by removing them and spraying them with a hose.
7/15/2012 12:34:07 PM • Blue Wave... • Answered on Jul 15, 2012
Why should I use a filtration system for my pool?
I have a pool in my backyard and could not imagine living without a filtration system. It filters out all debris and algae, leaving my pool clean and clear.
7/15/2012 12:30:22 PM • Blue Wave... • Answered on Jul 15, 2012
My favorite color.
Are you asking what your favorite color is? That's something you would know better than anyone else.
7/17/2017 7:22:08 AM • Blue Wave Pool &... • Answered on Jul 17, 2017
I have a blue wave inflatable spa. the ground fault blows when I turn the heater on. Is it possible to replace the heater element? If so, where can i purchase the part?
MarkI am not familiar with the Blue Wave inflatable spa however the ones we sell are replaceable so I would imagine that the Blue Wave one would be.Rodwww.uspartscenter.com
2/1/2013 4:50:39 PM • Blue Wave Pool &... • Answered on Feb 01, 2013
Azteck Pool. How to repair the skimmer wall please?
Videos, Repair Items and Articles that should help you.
Fair Oaks SW0 Standard Pool Skimmer Repair Kit
Amazon.ca https://www.amazon.ca > Fair-Oaks-Standard-Skimmer-... Allows you to repair your rusted skimmer area without replacing entire pool. Pool walls are made of galvanized steel which will eventually rust. This repair ... Rating: 4.7 · ‎137 reviews · ‎$131.45 · ‎In stock Missing: Azteck ‎' Show results with: Azteck
AZTECK MIXED MODEL 4 x 5.60 metre above-ground pool
My CFGroup https://www.my-cfgroup.fr > docutheque > anglais PDF P41129 Sand filter skimmer kit (AZTECK 7+1)**. 1 ... wall. Nut. Sliding washer. Page 35. 35. Using a detergent ... repair a pool or one of its component parts ...
Fair Oaks WM0 Pool Wide Mouth Skimmer Repair Kit
Amazon.ca https://www.amazon.ca > Fair-Oaks-Mouth-Skimmer-R... Fair Oaks WM0 Pool Wide Mouth Skimmer Repair Kit : Amazon.ca: Home. Rating: 4.6 · ‎83 reviews · ‎$184.79 · ‎In stock Missing: Azteck ‎' Show results with: Azteck
Pool Wall rusted out around skimmer - How to repair
Trouble Free Pool https://www.troublefreepool.com > threads > pool-wall-... Jun 2, 2020 - The rot has went passed some of the screw holes. How should I go about repairing this? Should I patch over with sheet metal and cut out a new ... Hairline crack in above ground pool skimmer 4 posts Jun 29, 2016 skimmer crack repair - Trouble Free Pool 11 posts May 28, 2013 Leak where skimmer meets concrete ' Trouble Free Pool 17 posts Oct 8, 2019 Grout repair around skimmer - Trouble Free Pool 8 posts Jul 17, 2022 More results from www.troublefreepool.com Missing: Azteck ‎' Show results with: Azteck
Skimmers and Returns
Pool Supplies Canada https://www.poolsuppliescanada.ca > accessories > skim... Swimming Pool Skimmers are complete with gaskets, weir (flapper) door, skim vac attachment, return fitting and directional eye. Return jets also available.
In-ground pool wall repair kit
Fair Oaks Products https://www.fairoaksproducts.com > store > IG-1084_In... -Stainless steel repair kit for in-ground pools with 8" wide skimmer opening. -Reinforces pool wall to allow attachment of skimmer. 15 1/4" W x 17 1/8" H ... US$178.00 images ..
4/26/2024 12:37:42 AM • Pool & Spa • Answered 6 hours ago
2answers
LifeSmart LS350 Plus Hot Tub Jet Spa. Can I convert my LifeSmart LS350 Plus 110v to a 230V
Question edited for clarity. Question moved from Computers category. Yes if you swap everything that is connected to electricity over to 220 volts. It is marketed as a 110 volt spa eliminating the problems of running 220 volt power. https://www.google.com/search?q=lifesmart+ls350+plus+220+volt ..
4/14/2024 9:55:26 AM • Pool & Spa • Answered on Apr 14, 2024
2answers
How do you clear a general fault on the power supply of Minimax NT5000 24V/15A-HR?
Contact the manufacturer 1 800 863 3930 for specific information about this. The manual does not include information for getting rid of a general fault. https://www.alpha.com/download/outside_plant_power/cableups_power_supplies/broadband_ferro/install_oper_manual.pdf
3/17/2024 4:14:55 AM • Pool & Spa • Answered on Mar 17, 2024
2answers
My Maax 461 Spa Heater heats constant until overheat and trips out until manually reset. If jets not turned on, the heater will overheat and trip. Acts like contacts stuck?
Question edited for clarity, 'till' refers to turning over soil, 'tilling', 'until' is the word you need. That sounds like a thermostat problem. The heater should only be on when water is circulating, even if it is just in the standby mode before the high pressure jets are turned on. Contact your installer or one of the parts suppliers in the link. It is unlikely to need a new mainboard. https://www.google.com/search?q=Maax+461+Heater ..
3/17/2024 4:08:41 AM • Pool & Spa • Answered on Mar 17, 2024
2answers
What is chemistry?
Chemistry is the branch of science concerned with the substances of which matter is composed, the investigation of their properties and reactions, and the use of such reactions to form new substances.
3/17/2024 4:06:29 AM • Pool & Spa • Answered on Mar 17, 2024
I am searching for an Aristocrat manual for the spa.
https://www.manualslib.com/manual/726129/Aristocrat-Usa-Mav500-Mkvi.html
1/8/2024 4:28:34 PM • Pool & Spa • Answered on Jan 08, 2024
OH Code how to correct so Spa runs?
OH Code is Overheat, so all the things you tried are not relevant. Low flow is normally the reason, too much heat build up in the heat exchanger so it cuts out. So, the next time your spa throws you a OH, OHH or some other "overheat" error code, you know what to do. Clean or replace the spa filter, open all the jets and turn the pump on high. If you still have problems, check over your temp sensor and high limit circuits for wire, plug or sensor problems.
Spa & Hot Tub Error Codes - OH, OHH, OHS
1/1/2024 4:40:07 AM • Pool & Spa • Answered on Jan 01, 2024
Leisureite GL2000 Spa. I am looking for a new cover for it please?
Question edited for clarity, spelling of maker and order of 'make model (what it is)'. Question moved from Sewing Machines category. It appears to be a New Zealand product made in Australia. We are in North America. This link should find you one and also has a link to the maker. https://www.google.com/search?q=+leisurerite+GL2000+spa+replacement+cover ..
12/11/2023 10:27:56 PM • Pool & Spa • Answered on Dec 11, 2023
Approximately, how many hand dips would you say you get out of a 3 lb Paraffin bath?
It should be plenty and you can reuse the wax once it sets anyway. https://www.google.com/search?q=3+lb+Paraffin+bath ..
12/3/2023 6:02:24 PM • Pool & Spa • Answered on Dec 03, 2023
Motor just hums does not run.
bad start up capacitor or motor
12/3/2023 3:50:52 AM • Pool & Spa • Answered on Dec 03, 2023
Blue Wave NFC0131 4-5/8 x 9-3/4 tsc filter cart Logo
5 questions posted
Top Blue Wave Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Blue Wave Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
  • Blue Wave Pool & Spa
Most Popular Question
cartridge filter need backwashed
  • Pool & Spa
