20 Most Recent
Dewalt DW297 3/4-Inch Impact Wrench Questions & Answers
Dewalt dw297 impact wrench does'nt work at all. the cables does'nt seem broken, so don't know what to look for.
A good place to start with Dewalt tools is the switch. Take the front off the handle and pull the switch out far enough to test the posts on the back. Plug the cord in and check for voltage where the cord attaches to the switch. No voltage, bad cord, replace the cord. If you have voltage, the cord is good. With some help, hold the switch on and check for current on the motor side of the switch. If no voltage, replace the switch. If there is voltage there, you are going to have to check the brushes, armature and/or field for continuity or shorts.
How do you change blades on DeWalt DW50 planer
https://www.weeklytools.com/different-uses-for-an-angle-grinder/
An angle grinder is a multifaced handheld power tools that was invented by a German company. We may don't know a lot about this tool because it is an unrecognized instrument like some other tools. Now we will discuss different Uses for angle grinder.
An angle grinder is also known as a side grinder or disc grinder. It is a machine with a rotating abrasive cutting disc. Angle grinders can be powered by an electric motor, petrol engine, or compressed air. It comes in a wide variety of different sizes and powerful motor, each with the other purpose. Once anyone knows about these, he can easily find out the best angle grinder for his needs. Angle grinders are quality fulled equipment for any metal fabrication shop, and those are typically used in auto repair, workshops, and construction sites.
Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
Why won't my DeWalt DC618K air nailer fire?
Without inspecting tool, it would be hard to definitely tell what part, I would call Dewalt, they will be glad to help you. You do not want to throw parts at it.
1-800-433-9258
