20 Most Recent Kwikset Polished Brass Lido Entry Lever and Deadbolt Combo Pack Featur Questions & Answers
2answers
Key will not come out in unlocked position
I presume you figured it out by now, but if the tailpiece is installed wrong in many deadbolts, the key won't come out in one position or the other. It's called a "timing" problem and the way to fix it is to take it off the door, turn the tailpiece a half circle and put it back on the door. Usually Kwikset locks are designed so you can't put it in the wrong way, but it can happen. (If it's not the timing problem, then the deadbolt unit is defective or broken. They are designed to fail in a way that keeps them locked, so this could be a sign that someone tried to break in, or that someone used the extended bolt as a way to stop the door from closing and it hit the door frame too hard.) The best way to install a deadbolt lock without the instructions handy is to look at the "lazy" cam and see if there is a way to install it wrong and don't install it that way. Example: If there are 2 ways for the tailpiece to fit in the deadbolt unit when the deadbolt is retracted and only one way for the tailpiece to fit in when the deadbolt is extended, then install the lock with the deadbolt extended and you can't install it wrong.
11/7/2022 1:45:58 AM • Kwikset Locks &... • Answered on Nov 07, 2022
How to remove the latch of a deadbolt with no latch screws?
Check out the videos. Some have a decorative cover that hides the screws. https://www.google.com/search?q=remove+the+latch+of+a+deadbolt+with+no+latch+screws ..
9/4/2022 8:01:50 PM • Kwikset Locks &... • Answered on Sep 04, 2022
Where is the model number located on a Kwikset deadbolt. I need to order a new battery case holder, but no longer have the box!
then go to a store in person and do the searching that needs done
4/17/2021 11:56:54 AM • Kwikset Locks &... • Answered on Apr 17, 2021
I have a 20+ year old kwikset deadbolt that I want to change the backset on from 2 3/4 to 2 3/8. It seems this is undoable on my model. Did you manufacture unadjustable deadbolts then?
No. Fixya doesnt manufacture anything. Fixya is for questions and answers and for fraudulent spam postings.
10/1/2019 8:01:08 PM • Kwikset Locks &... • Answered on Oct 01, 2019
I'm locked out of a shed with a Kwikset doorknob lock, key turns in lock but knob won't
I don't know if this is the best answer, but I would try to slip a heavy credit card between the door and the jam where the knob is. It may be a quick solution for the moment.
6/25/2019 10:16:35 PM • Kwikset Locks &... • Answered on Jun 25, 2019
Hello. I am trying to replace my old kwikset door knob. It has visible screws which I have taken out. It is impossible to take apart. Can you help?
Have you released the knobs? They are held on with a small depression thing on the stem of the handle. Press this in and pull on the knob to release it. Try the video it may be of some help but do the opposite to the fitting.
6/13/2019 12:42:22 PM • Kwikset Locks &... • Answered on Jun 13, 2019
Can I use my google assistant to contro my kwikset lock
notify kwikset
5/5/2019 2:24:32 AM • Kwikset Locks &... • Answered on May 05, 2019
How to override code on kwikset lock I am locked out
notify manufacturer or locksmith
5/2/2019 12:58:13 AM • Kwikset Locks &... • Answered on May 02, 2019
Kwikset Polished Brass Lido Entry Lever and Deadbolt Combo Pack Featur Logo
3 questions posted
Top Kwikset Locks & Locksmithing Experts
vince
john h
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Kwikset Locks & Locksmithing
Most Popular Question
retract kwikset lever signature series
  • Locks & Locksmithing
