20 Most Recent Baumatic B187 Stainless Steel Electric Single Oven Questions & Answers
My Baumatic Oven clock won't reset, even when I press in the second and third button. It keeps flashing 0.00 and is stuck in Auto. Help!
Flip the breaker off for a minute, then back on, this should reset it.
12/19/2014 1:43:32 AM • Baumatic B187... • Answered on Dec 19, 2014
My baumtic oven elemant burnt out and blew mains house fuse 30 amp,replaced both and nothing works nothing works
recheck connections or may have burnt a wire.
11/26/2014 9:08:06 PM • Baumatic B187... • Answered on Nov 26, 2014
0answers
When i turn electric oven on the house fuses blow no fan no heat
If this is a new oven, look at the plate on the oven or in the user manuel. It should show the input amperage. Then check the amperage number on the fuse. If the fuse number is lower, that is the problem. To fix it will not be easy. The oven circut needs to be rewired with heavyer gage wire and a larger capicity fuse. This could get expensive.If this problem is on an existing oven, chances are there is a wiring or switch problem. If you are not familier with electricity here is my recommendation.STOP! and call an electrition. the chances are high that if you try to fix this on your own you may be electrocuted or you may burn your house down.
11/18/2012 9:36:25 AM • Baumatic B187... • Answered on Nov 18, 2012
How to fit the splashback
Hi Do you mean the screws don't match up with the holes ? I find this all the time I drill new holes to make it fit correctly. One thing you should know is stainless is very hard to drill so go to the hardware store and get a bit for stainless and also get it just a little smaller then the screws, if you bring the screws with you they will help you get the correct bit , rate this call thanks Frank
12/13/2011 1:32:41 PM • Baumatic B187... • Answered on Dec 13, 2011
My grill works but the oven doesn't heat up
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.Oven Problems Electric Oven is Heating Slowly or Poorlyheatman101
3/31/2011 8:33:00 AM • Baumatic B187... • Answered on Mar 31, 2011
Baumatic B187 Stainless Steel Electric Single Oven Logo
63 questions posted
Top Baumatic Ovens Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
How-2-Repair.com
How-2-Repair.com
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
View Most Popular
Baumatic Ovens
  • Baumatic Ovens
Most Popular Question
oven tripped main fuse switch house
  • Ovens
