20 Most Recent
Baumatic B904SS Stainless Steel Electric Double Oven Questions & Answers
Front door as come away
Do yu mean the front door has pulled off it's hinges on one side or both ? if you hold the door on a angle about 12" open then press down towards the floor it will go back into place , if not you may have bent the hinges and the will have to be replaced
Bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
