20 Most Recent
Dell PowerEdge 1750 Server Questions & Answers
PowerEdge 1750 can not recognize the Local Harddrive
I think you need to provide heaps more info, like what operating system etc.. Have you tried to change the interface to another port eg if IDE, then move the cable to the secondary or if sata test the drive with another cable/port.. Have you tested the drive in another computer? OK, if it's scsi, then does the drive need a termination? Most scsi drives need a dongle or a terminator to allow them to be recognised.
NO POWER TO FLOPPY OR CD ROM NOTHING FROM THE GRAPHIC CARD
You need to list the problem in detail.
e.g. when you turn on , what do you see.
when does it stop.
do the lights come on
does the floppy or cd rom run
etc.,
without all these it is difficult to conclude on the possible malady.
it is same as going to the doctors and just sayint "I am unwell" and not providing what the problem is .
Good luck
David
Power is 2950 i912 sel full
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
STRIKE f1 ERROR
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
Format disk
what is your server model? in most cases you can use the operating disc to format the server drives
Serial number CDB6HJ1
Go to start menu. click on 'control panel'. Select 'system and security". Then select 'system'. This should give you the info.
