20 Most Recent
Dell PowerEdge 1600 ( pe1600sc/118/np ) Server Questions & Answers
Replacing cpu fan
These are the Dell part numbers for the PowerEdge 1600 SC heatsink:
7R181 Heatsink Assembly (Includes heatsink and fan)
83MGJ Heatsink Clip (2 required)
Dell spare parts can be reached by phone at 1-800-357-3355
Dell PowerEdge 1600sc server won't boot.
> black screen & flashing cursor ...
Damaged boot-record on the disk-drive???
Was it configured to try to boot from 'A:' ?
Disconnect the hard-drive & CD/DVD drives.
Put a diskette into the drive, and see if it tries to find a boot-record on the diskette.
If it tries, then it has P.O.S.T.'d correctly.
> no beep codes
When it worked, did it beep _once_ when P.O.S.T. completed?
Taking out the RAM _should_ cause some beep codes, i.e., "no RAM".
> anyone?
Replace the monitor?
Replace a dead video-card?
Or, add-in a video-card, and connect a monitor to it, leaving the original monitor connected to the original video-card. One of the two displays should show the P.O.S.T.
I bought dell sata hard disk but it is not
You enabled in the BIOS ... did it show a name/brand/size, etc.? You connected this directly to the motherboard or to a card inside? Did you go to Windows Disk Management (right-click My Computer, Manage) ... should show as Unallocated Space. Set it up here then you should be able to see it in My Computer.
How to install sata hard drive on dell power edge
You have to "FDisk" or "Partition" the Drive before Windows will see it.
XP - Goto: Control Panel | Administrative Tools | Computer Management | Disk Management
Vista/Win7 - Goto: Control Panel | System and Security | Administrative Tools | Computer Management | Disk Management
You will see hopefully both Drives... Highlight the New One... Create a New Partion by Right Clicking or use the Pull Downs. It will ask size etc... use the defaults.
Next Format the Drive - Select the Drive again...Right Click Format using Quick Format to save time and you should be set.
Keyboard, mouse, screen do not function?
you may have a bad mother board or power supply,however try a few of these,bare bone the system,no mouse keyboard,only monitor,remove all internal cards,power on.If no go remove memory ,power on if you get beep tones the motherboard is good.Question for you did the fan turn during these steps.Do you have a amber light on the power button,if you do the answer is you have a bad power supply.
Good luck
Dell power edge 1600 server
Is this hard drive in a RAID set? if it is, you will need to replace it with the exact same drive. After you do that, you will need to go into the RAID controller bios and initiate a rebuild.
Power is 2950 i912 sel full
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
STRIKE f1 ERROR
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
Format disk
what is your server model? in most cases you can use the operating disc to format the server drives
Serial number CDB6HJ1
Go to start menu. click on 'control panel'. Select 'system and security". Then select 'system'. This should give you the info.
