20 Most Recent
Dell PowerEdge 6600 ( pe6600/115/d ) Server Questions & Answers
Poweredge 6600 not showing display
If you have multiple video connections (onboard from motherboard, usually vertical or stand alone video card, usually horizontal) that you plug into the stand alone card, as the onboard is normally disabled when the expansion is installed. Verify the cable and monitor both work and that the monitor is on the correct input. Finally try another video card, if you have one available. Even if the drivers are not correct, etc, you should still see a boot screen.
Regarding Adding Higher Configuaration HDD Into Exisisting Raid 5
In raid 5 yes you can, yet you won't use the ful hard drive, the system will take only 73GB because that's the smallest HD in your array.
Just, of course, follow the indications for your specific RAID hardware/software about how to add a new HD to it:
http://support.dell.com/support/edocs/software/svradmin/1.9/en/stormgmt/cntrls.html
Power is 2950 i912 sel full
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
STRIKE f1 ERROR
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
Format disk
what is your server model? in most cases you can use the operating disc to format the server drives
Serial number CDB6HJ1
Go to start menu. click on 'control panel'. Select 'system and security". Then select 'system'. This should give you the info.
