20 Most Recent
Dell Dimension 8200 AUD System Board (0F141) Motherboard Questions & Answers
What is the maximum ram capacity of dimension 8200 motherboard
2 gygabytoes are usually the max, you could upgrade the OS to maybe Windows XP 64 bit, but this isn't worth it in such an olde machine! Throw it out and get yourself an ASUS laptop with Windows 7 64-bit, a solid state HD and 4 or more gigabytes of ram instead!. http://www.crucial.com/upgrade/Dell-memory/Dimension+%2F+Dimension+XPS/Dimension+8200+Series+%28400MHz+FSB%29-upgrades.html
Need cmos jumper location on Dell Dimension 8200
From what I can gather, you just need to locate the jumper labeled PSWD and remove it. Turn computer back on, then back off. Replace jumper pin and turn computer back on. That should do it. Removing the jumper disables password. Turning on computer resets it. Replacing jumper re-enables password capability.
Broke power button dell dimension 8200
your best bet would be to take it to your local computer repair shop in the hope they are willing to just help you out as it's a very easy repair.
failing that ask them if they have a spare switch of the samae type you need and repair it yourself. they normaly have lots of spare bits lieing around they might just give to you.
Out of date memory stick?
if its 250mb (will actually be 256mb) its probably pc100 sdram, can you give me your motherboard model number so i can tell you for sure of what it says on the stick of memory you have now
most places like scan/dabs might not sell the memory, but most likely can get it off ebay.
nedd the model numbers to be sure for you
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
