20 Most Recent
Nortel T7406e Cordless W/base - Nt8b45aaap Questions & Answers
Why doesn't the new installed battery help?
Question about Nortel T7406e Cordless W/base - Nt8b45aaap
But is not charging - as soon as the cahndset is removed from the charger, it indicates low battery, then will power off
How can I program the calls to go to the new location but same extension # on Nortel Networks T7316 phone?
To program the calls to go to the new location with the same extension number on a Nortel Networks T7316 phone, you will need to update the call routing information in the phone system's programming.
Here are the steps you can follow:
- Access the programming mode on the phone system. This typically involves entering a password or code on the phone's keypad.
- Locate the call routing configuration for the extension in question. This may be in a menu for "extensions" or "call routing," depending on the specific phone system.
- Edit the call routing information to reflect the new location of the extension. This may involve specifying a new phone number, a new group or queue, or a new set of forwarding rules.
- Save the changes and exit the programming mode.
Once you have completed these steps, incoming calls should be routed to the new location of the extension, even though the extension number remains the same. Note that it may take some time for the changes to propagate through the phone system, so it is possible that calls may still go to the old location for a brief period of time after the changes are made.
I have a Nortel Jazz 420 and it suddenly turned on pulse mode instead tone mode. How could I turn it on tone mode ? Pierre
Try this
Tone dialing allows your telephone to communicate with devices and services that respond to tone signals, such as answering machines, fax, or automatic switchboards. Want to learn how to switch from pulse to tone dialing on the Nortel phone? Follow these simple steps.
While on an active line, or after selecting the line, press # and the phone will switch from pulse to tone dialing. After you hang up the phone, your phone will return to pulse dialing. You may repeat these steps as needed.
