20 Most Recent Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt Cb Radio Questions & Answers
Connex CX3400HP 10 Meter Radio, volume problems.
Question edited for FULL 'Make model (what it is)'. Question moved from Hewlett Packard (HP). Clean all of the volume and rotary pots with electrical switch cleaner. That is NOT WD40. Also when inside check the soldered joints on them. https://www.google.com/search?q=Connex+CX3400%2C+volume+issues ..
6/26/2022 1:06:25 AM • Connex Cx-3600Hp... • Answered on Jun 26, 2022
Need more receive
Use a longer antenna or get it higher.. 102" whip for mobiles. maco v 5/8, army big stik, or Bandit for base. or a long beam 5 or 6 element type. for example..
11/18/2015 1:14:14 AM • Connex Cx-3600Hp... • Answered on Nov 18, 2015
I have a connex cx-3600hp cb and it sounds like it has no power
your power switch it faulty as there is a drop in voltage does the meters dim down?? then the voltage supply past the power switch it dropping as it draws more current or... the audio ic has damage or one of its associated capactors sometimes a diode can become leeky its used for AM modulation also
11/23/2014 1:53:25 AM • Connex Cx-3600Hp... • Answered on Nov 23, 2014
Why does the red light for antenna stay on
This means that your swr is high. you can damage the radio using it in this condition, check antenna and coax for damage or misinstallation
9/14/2014 7:59:32 PM • Connex Cx-3600Hp... • Answered on Sep 14, 2014
Has low volume with volume all the way up
You've been close to another big radio......you think that was a question but I believe it is the answer. The rf amp transitor or the diodes in that circuit have been damaged. So that stage of amplification is not stepping it up for the next. Resulting in the electrical power converted to air audio by speaker isnt available. Cb shops refer to this as a blow front end. Tr17 is the transistor location .......just a side note some radios have a mic circuit check that dulls audio levels this is not the case here.
6/14/2014 12:40:46 PM • Connex Cx-3600Hp... • Answered on Jun 14, 2014
I BOUGHT THE CX 3600HP 2 YEARS AGO. IT WOULD STOP WORKING FROM TIME TO TIME AND NOW IT WON'T WORK AT ALL. WHO DO I CONTACT ABOUT SENDING IT BACK FOR REPAIRS
Great Question. I'm not sure if Galaxy would work on a Connex . Copper Electronics has a repair department and would probably fix it for you. I'd offer but I don't have a lot of spare time right now. It's probably the power connection inside of the radio or one of the legs on the main volatage regulator broke loose from the pc bpaurd. That's a common problem with those radios.
2/21/2014 9:40:59 PM • Connex Cx-3600Hp... • Answered on Feb 21, 2014
0answers
Connex 4600 turbo what band do I need to operate in on channel 19 citizen band
This is a 10 meter Amateur Radio. You need a license to operate it. From my research it doesn't do CB Radio Frequencies. Here says Frequency Range 10 Meter 28~29 MHz https://www.walcottradio.com/connex-cx-4600-turbo-150-watt-10-meter-amateur-radio-p-2505.html and here shows your unit doesn't go low enough 26.960-27.410 MHz This Radio Standards Specification (RSS) sets out general requirements for, and provides information on, the certification of radio apparatus that is used for the general radio service, also known as the citizens band (CB), operating in the 26.960-27.410 MHz frequency band. https://www.google.com/search?q=connex+4600+turbo+cb+channel+guide https://www.google.com/search?q=Connex+4600+turbo
1/10/2023 3:17:56 AM • Connex Radio... • Answered on Jan 10, 2023
Swr will not go under 2.5 even with antenna adjusted up and down
if your swr is higher on 1 then on 40 then your antenna is electrically short and you have to lenghten the antenna.If it is higher on 40 then on 1 then it is long and you have to shorten it. If you have to make it longer then you may have to add a quick disconnect or a coiled spring to make it longer. To make it shorter all you have to do is trim a 1/4 in at a time off the antenna whip but you must keep checking the match until it gets down below 1.5 .
10/3/2018 8:00:49 PM • Connex Radio... • Answered on Oct 03, 2018
My connex 3300hp radio randomly transmits and gets stuck without pressing mic button. It in sticks if you press mic button.
Have you tried keying it without the coax attached ? Take the mic apart and give it a squirt of electrical parts cleaner .Try using a different mic also.
10/3/2018 7:50:40 PM • Connex Radio... • Answered on Oct 03, 2018
Converting connex 4400 turbo to a cb
If you disable any part of the radio that does not pertain to CB then you could actually do damage to the radio. the best thing to do is leave it on the CB band and don't touch it.
10/3/2018 7:47:39 PM • Connex Radio... • Answered on Oct 03, 2018
When turn radio on channel indicator searches but will not stop search 3400 connex 3400
the radio is searching for a strong incoming signal and until it gets one it will search for one. Try turning off the scan button .
10/3/2018 7:44:35 PM • Connex Radio... • Answered on Oct 03, 2018
Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt Cb Radio Logo
10 questions posted
Top Connex Radio Communications Experts
ADMIN Andrew
ADMIN Andrew
Patrick Patterson
Patrick Patterson
Level 1 Expert
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Connex Radio Communications
Most Popular Question
bought cx 3600hp 2 years ago stop
  • Radio Communications
