20 Most Recent
Connex Cx-366ce Night Runner 40ch Cb Radio, Very Loud Questions & Answers
I have a cx-366ce cb cannot hear talking what is wrong
Is squelch turned too high that it is blocking too many signals?
Otherwise, it could be a faulty cable on the mic as the PTT button disconnects the speaker on the CB and a broken wire can cause the speaker to be disconnected.
1 mile range on cb
Check cables and connectors. • check antenna SWR, A good SWR ranges from 1.2 to 1.5. • check power output.
Swr will not go under 2.5 even with antenna adjusted up and down
if your swr is higher on 1 then on 40 then your antenna is electrically short and you have to lenghten the antenna.If it is higher on 40 then on 1 then it is long and you have to shorten it. If you have to make it longer then you may have to add a quick disconnect or a coiled spring to make it longer. To make it shorter all you have to do is trim a 1/4 in at a time off the antenna whip but you must keep checking the match until it gets down below 1.5 .
Converting connex 4400 turbo to a cb
If you disable any part of the radio that does not pertain to CB then you could actually do damage to the radio. the best thing to do is leave it on the CB band and don't touch it.
