20 Most Recent
Sony Ericsson Naite J105a Unlocked Silver Questions & Answers
How i do solve mic problem
Could simply be a software issue if it works intermittently.
Other brands of phone have this problem when updates have been completed. Check the Sony Ericsson website for help.
Unlock sony ericson k660i
You can use codes to unlock your Sony Ericsson k660i! Unlocking using codes is easy and also the safest method!! You can get the codes from your service provider or from reliable online sites like
unlocking4u.com .You can get the codes by specifying Your phone's manufacture, model,country and network!The steps to unlock is simple here and the codes are affordable!!!!
I just bought a Sony
I upgraded my usb drivers -- I have windows xp pro -- i think they use all the same -- I used Realtek USB 2.0 card reader drivers. ( http://bit.ly/qeofyZ ) plugged it in (NOT in the front, but the back)_ & it recognized it after going to start, computer as "walkman" -- did a right click explore & all the data/music was still on the hard drive. then it showed on the walkman that it was charging & the battery was dead. i was previously using an AC usb adapter (plug in the wall) & it didn't seem to be charging it correctly -- so the computer works out for me & will only use that from now on -- fully operational.
My earphones will not work...when
Try adjusting your volume. If there is not a volume adjuster on your headphones, try turning it up on your phone. Hopefully it's not a shortage in the wire, which I don't think it is. Hope this solution helps; if not, reply back.
Booting error
Download Partition Table Doctor http://www.fileguru.com/apps/sony_walkman_mp3_nwz_b133f_boot_error/p2This will rebuild the device!!Best wishes to you!!!
