20 Most Recent
Kuppersbusch 24 in. IG6344 Built-In Dishwasher Questions & Answers
Dishes not cleaning properly
The problem is hard water. www.dishwasherfilter.com has a
product to solve this problem once and for all. It filters the water going into
your dishwasher and removes the hard minerals that leave those spots. It is
very affordable and even has a money back guarantee. You will love the way your
dishes look with this product.
Dish washer fail to activate the cleaning pills.
Faulty electronic sequencing releasing the tablet when cycle is ending, after drain, it is rather unusual. I do not think that is the problem.
Possible causes:
1. The machine does not fill or fill very little water, and this cause the released tablet not to dissolve.
2 The detergent drawer door is stuck for mechanical reasons, and opens very late. Opening is caused by vibration after the door had been released by timer board. Timer board release drawer door lock energizing the detergent door solenoid, but door stays closed until vibrations cause opening at the end of the cycle.
The first step is ensuring the machine is filling properly. The amount of drained water will not exclude underfilling. Check water level switch and inlet valve.
If filling is OK test detergent drawer and solenoid.
Kuppersbusch IGVS 659.2/IGV 659.2/IGVS 649.2
Hi mike_poulton,
I'm Harvey the master Plumber.
Your question is: You have one of the above models and it has been a fantastic dishwasher but now it seems not to take in water even on rinse and the timer does not decrease.
Any ideas please the model is 6 years old and if too expensive to repaire it will sadly have to go.
This may sound stupid but first make sure no one turned the water off to the d/w. If OK then you likely have a clogged or failed solanoid valve. The d/w must be removed for replacement. I don't recomend this for the average homeowner. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
