20 Most Recent
Kuppersbusch 23 in. IGV6435 Built-In Dishwasher Questions & Answers
Won't drain after wash cycle
sounds like you need a new drain pump, call currys partmaster quoting your model number and ask them for a quote on a new drain pump they are really easy to fit, or a local engineer in your area ll fit it for around £35
Water not going into dishwasher
Hello & Welcome to FixYa
When the water comes however, won't go inside the unit then it indicates that the problem is either with a clogged/blocked inlet valve or the water inlet valve itself has gone bad and needs replacement. You can also test two terminals of the water inlet valve before replacing it. Please get back to me if you have any other questions.
Kevin
