20 Most Recent
Sigma Telephoto 105mm f/2.8 EX Macro Autofocus Lens for Nikon AF-D Questions & Answers
I would like an instruction manual please.
The user manuals coming with lenses most of the time have little information about how to use them. The lens will have a MF and AF and perhaps a VR switch. If you want to learn more about macro photography, check this site from Ken Rockwell, where he is explaining how to do so with a Nikon camera.
Be aware the macro lenses are designed to focus close to the camera and will have the sharpest pictures close to the camera. I would not say you can't use a micro as a tele, but the results with a normal 105 could be better.
Still I think you have a great lens with your Sigma.
How to Shoot Macro
Hello, I just brought my
Turn the aperture ring to f/32 and leave it there. After that, forget the lens has an aperture ring at all. You can let the camera control the aperture in any mode except the M and A modes. In the M and A modes, you control the aperture by turning the command dial on the front of the camera, the same way you control the aperture on a lens without an aperture ring.
According to the manual for
In all modes the aperture ring on the lens should be locked at the smallest aperture. In the M and A modes you control the aperture by turning the command dial on the front of the camera. In P and S modes you control the aperture indirectly by turning the command dial on the back of the camera.
Sigma User Manual for 105mm f2.8 Macro
Well you can please follow the link below to get your manual -
http://www.dphotojournal.com/sigma-105mm-f28-ex-dg-macro-reviews-sample-photos/
(click on the manual tab and then click on - Download Sigma 105mm f/2.8 EX DG Macro User Manual (PDF – 67kb), thats it)
Good Luck!!
Thanks for using FixYa!!
Minolta to Nikon --Switching to Digital -- LENSE problems
Mirror lenses have no aperture nor AF, so they mount via a T mount. A $30 item that screws on the end of a mirror lens that fits your camera. A mirror lens has it's physical likes and dislikes against a glass 500mm. A glass 500mm will give a better image if you can stop down to F8 F16. Then you have shutter speeds to consider and those lenses are usually connected to the camera's contacts. So they can be specific to a single body. There are older Tamron lenses that take Adaptall mounts, they are old and hard to find. But they solved the multiple body problems for "auto" program lenses. None had AF, when AF camera around, we were back to individual lenses per body.
Where can I find out how to take apart a Sigma 150-600mm contemporary lens?
Taking it apart is not the problem - re-assembling it will be. Unless you have access to an optical laboratory, where laser instruments can measure the exact tolerances required, don't even think about it. You will be left with a pile of optical components, and a far higher repair bill than if you had just let the experts sort out the problem in the first place.
