20 Most Recent
Tappan TMT157E1 Microwave Oven Questions & Answers
Goodmans st101ss microwave no power
please follow this steps and fix it. God bless youLine FuseEvery microwave oven has a line fuse. This fuse is designed to blow if too much current is drawn through the microwave circuitry. The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.Main Control BoardIf the microwave is not working the main control board may be defective. This is not common. When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.Thermal FuseIf the microwave is not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.ThermoprotectorIf the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Tappan Speedwave 1000 turns on when door is opened
Microwaves do normally 'turn on', in that the light comes on and the fan starts running. If the turntable starts turning and it is emitting microwave energy, then you need to take it for service or replace it. To me, it sounds fine.
How do I get rid of the noise?
Hello, Sarkis -
I found 4 descriptions of what may be causing the noise when you operate your microwave oven. See the information on all 4 possible causes here:
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Microwave/78-88--/Tappan-Microwave-is-loud-or-noisy
Note: Safety advice I have read regarding microwave oven repair is to have a microwave oven repaired only by an authorized repair technician. It is not do-it-yourself work.
Any repair might not be worth the cost compared to purchasing a new replacement. A microwave repair technician authorized to work on Tappan microwave ovens will be able to evaluate what is causing the loud noise and give you an estimate of the repair costs.
Note: If you find you need to replace your microwave oven, please be sure the old microwave oven is sent to electronics recycling.
Best wishes.
I purchased our oven 06-04-1991.
Hey Twiddledum.... .. NEVER post this much info on line... the entire world can see it..(even bad people).. Sounds like this unit has served you well... price a new one...
My tappan microwave won't shutoff
I would first check the door switches and mounts. My door switch help file is
here.
If those are good, then you likely have a shorted relay on the control boar, which I can repair for you. Details are
here.
FixYa doesn't notify us when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
[email protected]
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
The display is showing the letters SE. What does this mean?
Unless there is moisture or grease on the control circuit board, "SE" error means you have a shorted membrane keypad.
The solution is actually a pretty simple DIY job - to replace the control panel frame assembly - which comes with a new keypad already installed.
If I had your full model number from the tag on the oven I could likely give you step by step instructions with the part number you need.
You can find links to helpful exploded view diagrams and part ordering help
here, where you can also e-mail me directly.
I recommend that you bookmark that link to your favorites.
How do I get to the fuse on my cabinet tappan microwave?
Then you have blown a fuse. Check inside the oven chamber and look for missing powder paint or signs of arcing, if so dispose of the microwave. If the inside is good remove all the screws and remove the cover. Replace the fuse. If the magnetron was making louder noises prior then replace the magnetron. Since the fuse went the giant capacitor is likely bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
