20 Most Recent Harman Kardon HD720 CD Player Questions & Answers
Cd holder opening all the time
I don't know your specific model, but this problem is a common one. There is a loading belt that not only pulls the tray into the machine but also engages the cd onto the CD table with a clamping assembly. If the belt is starting to slip, it won't have enough grip to engage the clamper. This means that the load is unsuccessful and the unit will "eject" the CD. Have the loading belt replaced and all should be well.
Dan
11/6/2009 5:38:42 PM • Harman Kardon... • Answered on Nov 06, 2009
Harman Kardon AVR 630 8CH mode not available
According to the Harman-Kardon AVR 630 User Manual, if the 8CH mode is not available, you can try unplugging the unit from the AC wall outlet and waiting for at least three minutes. After the pause, reconnect the AC power cord and check the unit's operation. If the system still malfunctions, a system reset may clear the problem. The 8CH may not be available according to the user manual. You need to contact Harman-Kardon customer support.
10/26/2023 1:09:22 PM • Harman Kardon... • Answered on Oct 26, 2023
Harman Kardon 3490 Stereo Receiver. The standby light on but won`t turn on when power button is pressed.
Check the power button first. It is Ok ? It may require replacement.
10/23/2023 1:30:40 PM • Harman Kardon... • Answered on Oct 23, 2023
2answers
Hello, Our Harman Kardon receiver HK 3450 is showing error on desplay, and nothing realy goes. Also, when I put on the system, first, the left speaker makes a brrr noise for a little while...
i recommend you turn off the receiver and then disconnect it from the power outlet for a few minutes
8/31/2023 12:06:16 PM • Harman Kardon... • Answered on Aug 31, 2023
HOW I CAN CONNECT MICROPHONE IN HARMAN KARDON AVR-141/230
headphone is audio out for your headphones not audio in. you will need to buy mic pre amp and use output to aux or preferably tape in RCA connectors.
4/19/2023 4:59:16 PM • Harman Kardon... • Answered on Apr 19, 2023
2answers
Harman kardon avr 146 no front led display. but clicks on from orange light to blue. is there a fuse for display screen ? fuse at AC in is OK.
Hello, there is no fuse for the screen, there is a power supply circuit that makes it work and that if it is wrong the screen does not work The rest of the team works well? Can you hear something? if not, you do not have a display problem, you have a bigger problem If you have knowledge to review it, I will attach the service manual, but go to a specialized technical service Hola, no hay fusible para la pantalla, hay un circuito de fuente de alimentaci?n que lo hace funcionar y que si esta mal la pantalla no funciona El resto del equipo funciona bien?, puedes escuchar algo? si no, no tienes un problema de display, tienes un problema mayor si tienes conocimientos como para revisarlo, te adjunto el service manual, sino dir?gete a un servicio t?cnico especializado https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Harman-Kardon-AVR-146-Service-Manual.pdf
9/25/2022 8:24:59 AM • Harman Kardon... • Answered on Sep 25, 2022
2answers
Harman Kardon AVR PROTECT mode seconds after turning it on. No speakers are connected
Fault in one or more channels. Take your DVM and test for short circuits or take it to an HK repair shop.
9/25/2022 8:24:01 AM • Harman Kardon... • Answered on Sep 25, 2022
Poor Bass from my AVR-141
try electronic cleaner on volume
9/25/2022 8:17:33 AM • Harman Kardon... • Answered on Sep 25, 2022
Where can I get a schematic for a Harman Becker BEB200 amplifier?
Contact Harmon Kardon directly to inquire.
3/30/2022 11:37:11 PM • Harman Kardon... • Answered on Mar 30, 2022
How do I access the capacitors on the bottom circuit board in Harman Kardon AVR3550? Can I get to them from underneath the unit?
Normally when you remove a unit's case everything is fixed to the base and the back. You remove the screws in the board and lift it up. See if this video helps, which is also a capacitor removal. https://www.google.com/search?q=harman+kardon+avr3550+replace+caps ..
3/22/2022 2:33:28 PM • Harman Kardon... • Answered on Mar 22, 2022
My Harman kardon player is stuck on d aux mode whenever I put it on.
My harman kardon BDS 577 is stuck on aux mode pls pls help
12/26/2021 10:51:32 AM • Harman Kardon... • Answered on Dec 26, 2021
2answers
I have a Harman kardon 1700Avr that is stuck in protect mode, Is there anyway to bypass or reset it? Thanks....
It's in the protect mode because of a component failure inside. It needs to be repaired to get out of the protect mode.
6/13/2021 1:53:28 AM • Harman Kardon... • Answered on Jun 13, 2021
Harman kardon avr 510 reset
Page 53 of the manual
Troubleshooting Guide; Processor Reset - Harman Kardon ...
https://www.manualslib.com > ... > Owner's manual
Harman Kardon AVR 510 Manual Online: troubleshooting guide, Processor Reset. Symptom Unit Does Not Function When Main Power Switch Is Pushed ...
6/4/2021 4:23:04 PM • Harman Kardon... • Answered on Jun 04, 2021
Good day, please I do I fix my Harman Kardon protect shut down?
Xplain with more details.....
6/1/2021 4:17:22 AM • Harman Kardon... • Answered on Jun 01, 2021
When i turn on my Harman kardon ts 15 subwoofer it produces a continuous booming sound
That is most likely an amplifier driver transistor that has failed.
10/14/2020 3:53:19 PM • Harman Kardon... • Answered on Oct 14, 2020
Harman Kardon HD720 CD Player Logo
1 questions posted
Top Harman Kardon Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Sean Wright
Sean Wright
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Harman Kardon Audio Players & Recorders
Most Popular Question
cd holder opening all time
  • Audio Players & Recorders
