20 Most Recent MSI KM4AM-V Motherboard Questions & Answers
manual
I have ms-7601 mohterboard i unble
Hi, you can download a manual from here:
http://eu.msi.com/product/mb/KM4AM-V.html#/?div=Manual
Please unzip the file before you can read it.
8/30/2011 10:22:27 AM • MSI KM4AM-V... • Answered on Aug 30, 2011
How to reset the BIOS on via ms-7061 mother board
You can either flash the bios or open the case and push the reset button to restore default settings. The easiest way would be to goto the vendors website & download the latest Bios update & do a flash. The vendor will give detailed instructions. You can also google the manual for your board which will show where the reset switch is
7/3/2009 1:30:24 PM • MSI KM4AM-V... • Answered on Jul 03, 2009
Driver require
ok this is ur driver rate me fix ya hehe
http://download2.msi.com.tw/files/downloads/bos_exe/7061v12.zip
11/28/2008 11:55:33 AM • MSI KM4AM-V... • Answered on Nov 28, 2008
Wont boot into bios
Hi anp62, you can contact MSI & order a new bios chip. Most manufacture's charge about $5.00 US.
It is worth it before trashing the board. You can contact MSI at the link below. http://www.msicomputer.com/support/OnlineTS.asp
Check MSI's Basic Troubleshooting Guide, so I don;t have to type all these checks.
Click here: http://www.msicomputer.com/support/sup_tshoot.asp
Mike
9/26/2008 3:00:33 AM • MSI KM4AM-V... • Answered on Sep 26, 2008
2answers
DRIVER
Hi - You can download the software from the link underlined in blue below:
KM4AM-V
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
8/25/2008 1:16:47 PM • MSI KM4AM-V... • Answered on Aug 25, 2008
Motherboard
there is a live update on line here to search for your required drivers
http://global.msi.com.tw/index.php?func=downloadindex
8/17/2008 12:51:21 PM • MSI KM4AM-V... • Answered on Aug 17, 2008
Require driver
I want a driver of motherboard. model- ms -7061(MSI KM4AM-V)
ver-1.0 ,
8/15/2008 5:50:12 PM • MSI KM4AM-V... • Answered on Aug 15, 2008
Lcd monitor resolution
Hi, if I understand you right, your LCD can display 1680 X 1050 but your PC/Video can only display a max screen resolution of 1280 X 1024 (or something like that). Right click on your desktop, go to properties, Go to the settings Tab, see how high you can bring the screen resolution (towards the right). That is the limitation of the built-in video (S3 Graphics UniChrome 2D/3D Graphics with motion compensation) of the MSI KM4AM-V (2004). If this will do for you, then you're set, if not then..... To be able to display resolution higher than that, you have to add an AGP Video card capable of the 1680 X 1050 (ATI or NVidia or your choice as long as screen res is high). Your motherboard has one AGP (Accelerated Graphics Port) slot @ 1.5V 4X/8X. This will also hold if you already happen to have an AGP Video card but with relatively low screen res. Hope this be of some help to you. Pls post again how things turn up. Regards
5/4/2007 2:38:41 AM • MSI KM4AM-V... • Answered on May 04, 2007
Booting problems
As you probably have already figured out your motherboard is running into some type of error during the boot process. Try restarting the computer and pressing the del key several times after a second or two. Can you get into the BIOS now? The first thing I would do is to make this as basic a machine as possible: remove and add in cards (except primary video card), remove all USB components, reduce the size of your memory (RAM) and if you have multiple hard drives remove all except your boot drive. Unplug your computer, plug it back in and reboot, paying close attention to anything that is displayed on the monitor and noting any changes from before. If nothing changes can you tell us some more about the status of the computer or what led up to this? Did you just build it; just install a new part, power problems, anything? Let us know what you turn up and please don?t forget to rate the posting.
1/6/2007 11:53:48 PM • MSI KM4AM-V... • Answered on Jan 06, 2007
2answers
How do i download MSI N082 graphics driver
To get the MSI N082 graphics driver: 1. Find your graphics card model. Note down the model number. 2. Go to MSI's website. 3. Look for the support or downloads tab and click on it. 4. Use the search or menu options to find drivers for your specific graphics card model. 5. Download the driver package. 6. Run the installer file once the download is complete.
3/26/2024 10:36:50 PM • MSI Computers &... • Answered on Mar 26, 2024
Screen does not fit after adjusting the screen resolution msi N082 i tried updating the VGA driver online but it keeps telling me that driver is up to date
If adjusting the screen resolution didn't resolve the issue and you've already updated the VGA driver, try manually adjusting the display settings through your computer's control panel or display settings menu. Look for options like overscan or scaling to ensure the screen fits properly. If the issue persists, it could be a hardware problem or compatibility issue with your monitor. Consider reaching out to MSI support for further assistance.
3/26/2024 12:50:33 PM • MSI Computers &... • Answered on Mar 26, 2024
How do i connect my fire stick thru bluetooth on my MSI windows 11 laptop??
To connect your Amazon Fire Stick to your MSI Windows 11 laptop via Bluetooth, you will need to follow these steps:
  1. On your Fire Stick, go to Settings > Display & Sounds > Enable Bluetooth.
  2. On your MSI Windows 11 laptop, go to the Windows Settings > Devices > Bluetooth & other devices.
  3. Turn on Bluetooth on your laptop and make sure that it is in pairing mode.
  4. On your Fire Stick, select your laptop from the list of available devices.
  5. On your laptop, click "Pair" when prompted to complete the pairing process.
  6. Once connected, you should be able to stream content from your Fire Stick to your laptop.
1/20/2023 11:59:27 PM • MSI Computers &... • Answered on Jan 20, 2023
Wanting to connect an older AV received to my Win 10 PC via optical input. Should I use MB or Graphics output?
You should use the audio output on your computer that is labeled as "optical" or "S/PDIF" (Sony/Philips Digital Interface Format) to connect to the optical input on your AV receiver. This will typically be labeled as the "digital audio out" or "digital output" on your computer. The "graphics output" is used for video, not audio.
1/12/2023 2:39:40 PM • MSI Computers &... • Answered on Jan 12, 2023
How can i enter the bios on my pc.
Proper training and equipment are needed to modify the (Basic Input Output System ) BIOS on a PC. You could turn your PC into a paper weight. The game has been criticized for its anti-cheat software, Vanguard, as it was revealed to run on akerneldriver, which allows access to the computer system.[56]OSNewsexpressed concern that Riot Games and its owner, Chinese technology conglomerateTencent, could spy on players and that the kernel driver could be potentially exploited by third parties.[56]However, Riot Games stated that the driver does not send any information back to them, and launched abug bounty programto offer rewards for reports that demonstrate vulnerabilities with the software.[57][58]The bounty will reward white hat hackers between $25,000 to $100,000 for reports on its vulnerabilities, with the pay being based off the severity of the exploit.[59]Gameplay bugs do not qualify for this bounty.[59] Valorantwill not run onWindows 11if the system does not have aTrusted Platform Module(TPM) 2.0 compliantcryptoprocessorandUEFI secure bootenabled, as mandated by Microsoft's minimum system requirements for the operating system.[60]
11/20/2022 7:19:17 PM • MSI Computers &... • Answered on Nov 20, 2022
Replacing an msi laptop screen
no PC told at all MSI is maker only but yes they all unplug on laptops(is it) they are held on by tricky ways and if forced you break mobo or display there are the easy ones push on pull off the the wedge locked, , unlocked first. and last the hinge lock FFC cable ends learn not to force them, look first for locks, 2/3rs of them are locked.
8/22/2022 8:33:42 PM • MSI Computers &... • Answered on Aug 22, 2022
I need the MSI MS7506 AMD AM2 Bios bin file
Contact AMD.
8/1/2022 10:43:59 PM • MSI Computers &... • Answered on Aug 01, 2022
I was using Sony
the reason you get lost is using bummer APPSlike nero or worst. doget Imgburn , free and safe and solid.use test mode.the do a test mode burnit now tells you exactly what fails. (sure does)and this is why, sure is.(filenames too long or?)"I know some units require a specific brand of blank CD" this is not really true.no player or burner has ODD media restrictions on brand. (ODD disk are really PnP disks that have ID track that tells the host what the disk can do, in every possible way)sure there are vast brands that are pure trash sure.just like tires car or the like. BRAND WISE.like old Firestonedeathtires. (cured by new owners)The Imgburn does fail on bogus medialet me explain, gee seen it all I havethe china import CD-r. has the ID track all configured illegallly, is invalid. so the burner warns of that pronto.a blessing that, like :::: illegall(sic), disk size or makers name missing or the burn limits stated are missing (useless hard nut fail here)a burner can not burn lacking this key ID track set correctly by the maker ( a must be good thing)a classic case of pure junk CD-r or DV-R or BD-Rtry TDK and verbatum and end this junk grade folly.
6/14/2022 3:45:01 PM • MSI Computers &... • Answered on Jun 14, 2022
The first of four led lights FLASH ON and 0FF ON A970-G46 MOB AND MY POWEER SUPPLY TESTS GOOD. All componets work good on my 2nd identical MSI MOB. CAN THIS MOB BE FIXED OR MUST I REPLACE IT?
four led lights where are they? lost the manual? Desktop mobo. MS-7693 (v2.x) Manboard 970a or 970S? all led x4 status indicators. on mobo top 4 glow means phase 4 power level. page 32. coin cell dead is #1 for all PCs over 5 year and for sure 7. a dead mobo, bios screens dead, that it,???? what gpu card what monitor ? all fans dead? support for vista or w7 , so that? bios HOT KEY IS <del> THEN F11 (BIOS II)? 2 MOBO 1 GOOD 1 BAD USING SAME CPU AND 1 STICK OF RAM.? same PSU>? wired same to mobo? THIS MOBA HAS NO VGA IGPU PORT ON REAR SO MUST HAVE GPU CARD or there can be video ever. and see bios. and reset bios first and new coin cell first. 7years old that coin is and will be a pain now or soon. a $ 1 fix. gpu card into top x16 slot????? GPU card over 75watts must have gpu aux power wired to it or it will be dead, from PCl. psu wired to JPWR2 ? must be. and JPWR1 both. or cpu will be dead. that is about it , on this 2011 mobo. no gpu card top in fact full speck on all things connected to the mobo no told, including all devices all cables, and cards. and port. not told.
5/23/2022 4:34:28 PM • MSI Computers &... • Answered on May 23, 2022
Can't enter bios (MSI 870AG46) the puter boots and runs the RAID setup and displays the 5 options, after exiting it skips the BIOS setup screen.
NO OS TOLD AT all and want help<. really? I will guess w7 ! Bios hot key is <del> on pad , numlock off. NO drives told tell me it is sata boot, drives not relic junk IDE (pata) in bios disable raid and save BIOS main <DEL'> hot key. the coin cell is dead why skip act 1 ? 7 years old is max life. EOL so replace that first reset bios inside bios see time and date set raid CHIP OFF, in bios set boot order of HDD 0 boot is there and good HDD safe exit cold boot it. install w7 is max ,w8 up lacks key drivers for the mobo seen below. link to makers site if your read the manual and see page on control+F RAID rom there all you need is there, in that free manual. page 72 B2 quote "Important Be sure to enable the RAID functon for SATA devcen BIOS before configuring the RAID Opton ROM Utlty." the means same in reverse too, to disable radio do so on main bios there are to bios here,main and raid. page 48 https://us.msi.com/Motherboard/870AG46/support#manual books there and all w7 drivers too. main raid mode, (off)
5/23/2022 4:06:02 PM • MSI Computers &... • Answered on May 23, 2022
MSI KM4AM-V Motherboard Logo
Popular Tags
13 questions posted
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
driver
  • Computers & Internet
