20 Most Recent
MSI K8T Neo-FSR Motherboard Questions & Answers
My hard drives r cleared of everything? and now it
I take it that you have erased your hard drives and are trying to re-created a RAID array.
I have found that formatting a drive may not remove the RAID information. what i would recommend is using a utility to zero out the first section of the drive(50-100MB of data) that will ensure that all the RAID info is removed from the drive and then you can attempt to re-create the array.
if your familiar with a Linux system you can use the the "dd" utility to zero the drives.
Hola buenas tardes queria
Do the updates from Microsoft some times they are there if not go to the maker of *********** board and look under they're support they should have them.
Want to add a second hard drive and am wondering
usual all have tow provision set of IDE cable and more power cables , just use them to add your second Hard disk, if you are not more clear just see this tutorial ,
click here to view , but now a days all getting external hard drive to make it more easy to do this process. It will be available in all Hardware shops.
Good luck ! if you think your problem solved don't forget to rate
I get a bleu screen
Hi, Make sure the hard drive is formated, then install XP,
but the XP disc may be faulty, any marks on it?
sounds like a software prob,
hope this helps
I had to reinstall window
You need not to worry, all the driver can be found at the msi website...
you just need to go here, click drivers and install all of them after downloading.
>>http://www.msi.com/index.php?func=proddesc&prod_no=565&maincat_no=1
or
click herehope this will help for sure...cheers:)
How would you know what type K8T Neo of
The manual is mostly the same.
MSI K8T Neo is also, MS-6702 (v1.X) ATX Main board. You'll find K8T Neo printed just in-between the first and second PCI slot.
In-between the second and third PCI slots you should see, MS-6702 ver 1.0 (Printed in white). All 5 models use the same chipsets. VIA K8T800 PRO Northbridge and VT8237R/Plus Southbridge. K8T Neo-FSR/ FIS2R Socket 939 use the same manual.
K8T Neo-V V2.0 uses a socket 754 CPU.
K8T Neo2-F V2.0 Also uses socket 754 CPU.
K8T Neo2-F-FIR Uses a socket 939 CPU
So open the link provided for drivers, bios ECT;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+Neo&table=download
The most noticeable item is the SATA ports. From 2 ports and up to 4 ports. In different locations on the MB.
Did you find this helpful?
Mike
Intel motherboard how to find power
It is silkscreened on the moterboard at the bank of pins for the switches and lights. it is usuall abreviated as PWR SW, RST SW, HD LED, SPKR, PWR LED, ...If it is not silkscreened then look at the manual on the manufactures website. they will have a photo of the MB with it illistrated. go to
http://www.retrevo.com/support/MSI-K8T-Neo-FSR-manual/id/8353ci976/t/2/
Cannot get BIOS to boot from DVD drive.
you can try this option to if you sure that your dvd drive is working properly remove the battery on the motherboard and put it back this operation srestart to bios and try again to boot from dvd drive.
Motherboard won't recognize SATA DVD drive.
make the dvd your 1st priority in bios for boot, if it cannot be recognized try taking the floppy cable out of the floppy drive, maybe you have a problem with your power supply
Board is not recognizing my 80G Maxtor drive. I
with AmiBios you may be able to get it to rediscover your drive... If that doesn't work, open the case and check your IDE and SATA connections. Sounds like you have a RAID configuration with your Promise board.
Not sure I've helped, but you have some clues to check on. Probably visiting Promise's website and looking for troubleshooting may help.
If your Maxtor drive is a SMART drive, you might be able to check to see if it indeed has failed.
