20 Most Recent Canon EOS Elan IIE 35mm SLR Camera Questions & Answers
Eos A2
7/18/2016 9:09:42 PM • Canon EOS Elan... • Answered on Jul 18, 2016
Canon eos elan II-e, film door wont latch shut.
7/18/2016 8:12:36 PM • Canon EOS Elan... • Answered on Jul 18, 2016
Film door latch broken.
7/18/2016 6:22:59 PM • Canon EOS Elan... • Answered on Jul 18, 2016
I have mounted a M42 adapter to my Elan IIe. It
i have some problem with elan 7 when i mounted m42 adapter and manual lens the expouser mode is gonig crazy i have very wrong exposer not one or two step its more one eos 300 canon its allright whats a problem? thanks evryone
4/11/2011 7:02:29 PM • Canon EOS Elan... • Answered on Apr 11, 2011
The camera back button requires power to operate
I had a Canon Elan IIe and I don't recall having to have electronics to open the camera back.
Make sure you have a battery in it, turn it on look at the LCD panel and see if it has film in it.
If so you should be able to push the "mid roll" film rewind button located on the back left side it shows a film canister icon. Once the film has rewound into the canister release the back with the mechanical latch found on the left side (while facing the back of the camera) just push it down and the back will pop open. Those cameras are pretty darn good and the only thing I've seen friy the electronics is using an "old" type flash on the hot shoe and that takes the flash circuit board and melts the thing. I'd expect the camera battery is dead and you can't rewind the film back into the canister.
12/1/2010 12:42:32 AM • Canon EOS Elan... • Answered on Dec 01, 2010
EOS 30 how to remove film from camera, as camera
The easy way is to use a film changing bag, if you don't have one follow the instructions below:
You need to get the film out manually. In a darkened room, just a very small/dim lamp, or door open where the light is in the next room.
First check where the lever/switch is for opening the camera, remember where it is. Then put the camera under some jackets/blankets to protect it form any light. Put your arms under the covering keeping them flat with the surface so no light can seep in.
Open the camera by feel then pull out the film canister and start winding the film back into the canister manually by turning the canister spindle, always keeping the camera and film and hands/arms protected from light under the covers. You might have to tug a bit on the film to get it from the take-up spool inside the camera.
Some cameras have a button on the outside underneath the take-up spool, which you press to release the spool, I doubt that your camera has this because it is auto winding & rewinding?
11/6/2010 3:29:00 AM • Canon EOS Elan... • Answered on Nov 06, 2010
I have got an EOS Elan II E Film Camera (Cannon).
Hi, all canon EOS digital cameras can take all EF lenses. An EF lens from 1989 will fit a Digital body from 2009.
The newer EF-S lenses will only work with the smaller APS-C size sensors on the cheaper consumer bodies.
Hope this answers your query, please take the time to rate!
4/10/2009 11:41:13 PM • Canon EOS Elan... • Answered on Apr 10, 2009
Door will not close
Door Latch can be changed easily.Remove fascia panel screws,and latch cover screws;ease fascia panel forward slightly to enable unhooking of spring.Carefully remove latch and fit new part(£7-50 from Lehhmans at Stoke on Trent.).Do not bend contacts.Refit all screws.Job Done.(10mins)
10/13/2008 7:32:18 AM • Canon EOS Elan... • Answered on Oct 13, 2008
Auto rewind problem
There are 2 things that can cause that problem. Many times it is caused by the user pulling too much film out of the film cartridge and laying it across the film plane, causing it to bunch up on the take-up roller when the camera back is closed.
Make sure the film tip extends no further than the orange indicator in the back of the camera.
If that is not the cause, there is probably a defect in the clutch that flips back and forth each time the camera winds the film. Sometimes they bind up and cause the camera to go into the rewind mode early. It would need to be looked at by a qualified camera technician to determine if that is the problem.
CameraRepairs
8/11/2008 2:36:43 AM • Canon EOS Elan... • Answered on Aug 11, 2008
Broken latch on hinged back
Try calling Canon's parts department at 1-732-521-7230 and see if they still have the part in stock. The part number is CF1-3129-000 and should cost less that $2.00 I think.
CameraRepairs
8/11/2008 2:25:49 AM • Canon EOS Elan... • Answered on Aug 11, 2008
Need replacement Shutter for EOS ELANIIE
You can order the shutter assembly from Canon or just the 2 blade assemblies if that is the only problem.
The part number for the entire shutter is CG1-3155-000 and the individual blade assemblies are CF1-2763-000 and CF1-2764-000.
Canon's parts phone number is 1-732-521-7230
Please note that the Elan IIe is a very complicated camera, beyond the capabilities of most do-it-yourselfers. However, you may still want to give it a try!
CameraRepairs
8/11/2008 2:23:27 AM • Canon EOS Elan... • Answered on Aug 11, 2008
Canon EOS ELAN II E built in flash
I cannot locate the parts diagram for the Elan II e but I did find a PDF for the Elan 7. The flash should be very similar, look here;
Canon Parts List
1/30/2008 3:37:41 AM • Canon EOS Elan... • Answered on Jan 30, 2008
2answers
Canon AE-1 Program needs cleaned or am I missing a step?
Hello
Thank you for using FixYa for your problem
I am guessing it may of been lying around for a while, some of the parts have stopped moving right, a good strip and service will solve it. There was a manual to service these years back or take to a service agent
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
12/1/2018 5:44:46 PM • Canon... • Answered on Dec 01, 2018
tip
Saving Money On an External Flash for your DSLR
Save money (lots) by NOT buying a name brand smart flash for your camera. Bottom line - Expert photographers use manual settings on their cameras and their strobes to take photos. It is the newbies, occasional shooters who need the auto settings (see exceptions) - and the auto settings that cost so much on the external flash units for Canon and Nikon Cameras. A "smart" flash from Nikon could cost more than $600 while a "not smart" third party flash should cost $40 or less. "not smart" means that you tell it how powerful it should be when the shutter is released - and then it gives you the light you set when you click. A "smart" flash takes into account the surrounding light and the aperture set in the camera in order to determine the power of the flash delivered when the shutter is clicked. "Smart" flashes also have a manual mode. Why do you need an external strobe unit? Don't you already have a flash built into the body of the dslr?? First - the strobe built into your camera is pretty weak. Second, it is immobile. Third, it is only a single point of light. With a dedicated power source (generally AA batteries) an external strobe has more power. The strobe head can be rotated and pointed in almost any direction. By being removed from the lens about 4 inches, it is often enough to eliminate red eye in photos of people. And, by being movable, the photographer is able to control shadowing on the subject. A further benefit is most of these strobes come with a 'built in slave', meaning that the light from one flash unit can trigger the flash of another flash unit. That means that for less than 25% of the price of a "smart" unit, you can afford 3 or 4 of the "not smart" units and control them with your built in flash. This gives the photographer a great deal of creative flexibility and the ability to light up an area far away from the camera - wirelessly. for more on the use of an off camera flash, search strobist with your search engine. exceptions - there are certain situations where the brain of the flash computer is really helpful to adapt to quickly changing lighting situations and from a practical standpoint, manual settings may not be able to keep up with the changes without missing the shot. An example is weddings where the venue moves from well lit to poorly lit places or in and outdoors, or in and out of shadow situations. But, most shots are taken in a venue where lighting doesn't change and hundreds of shots are taken in virtually the same setups, same distances, etc. Here the camera can (and probably should) be set to manual settings and the flash also set to manual power. In fact, by using automatic settings, there are many processes that have to work perfectly in order for the proper exposure to be taken. These processes take computing power and an instant of time - which, depending on the computing power of your camera, could cost you that shot. But, if you are taking wedding photos and faced with varied lighting situations, hopefully you can afford good lighting tools.
on Feb 25, 2018 • Photography
My canon A1 shutter fires at all speeds, mirror
Your shutter leavers are getting slow. They will fail soon, most likely the old grease is sticking. You can get a replacement body for $40 as repairs/cleaning will be $80+
2/20/2018 5:41:42 PM • Canon... • Answered on Feb 20, 2018
My camera got slightly splashed with water, I
It is unusable because it is 'broken'. You've not specified the make and model, but if it was a cheap one (under £500) just replace it.
12/10/2017 9:54:04 PM • Canon... • Answered on Dec 10, 2017
I have a Canon Rebel
I'd check with Canon. They will probably want you to send it back . . . be sure the price of the repair is going to be considerably less than a new (refurbished) camera.
11/2/2017 3:50:35 PM • Canon... • Answered on Nov 02, 2017
Low battery indicator, even after a new battery
You probably have a dead cell in your replacement battery. Camera batteries have a limited number of charge cycles, and this is not a rare issue with "aged" batteries. Also, when you get a new battery, buy a genuine Canon replacement and not one of the el-cheapo Chinese copies available online. In camera batteries, you really do get the quality and performance you pay for!
10/6/2017 1:59:06 AM • Canon... • Answered on Oct 06, 2017
Canon EOS Elan IIE 35mm SLR Camera Logo
13 questions posted
Top Canon Photography Experts
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Canon Photography Expert? Answer questions, earn points and help others
View Most Popular
Canon Photography
  • Canon Photography
Most Popular Question
canon eos elan ii e film door wont
  • Photography
