20 Most Recent Panasonic Th-42px25u/p 42-inch High-definition Plasma Tv Questions & Answers
Volume control stops working. Tried an identical remote and setup 993, no luck Even using the volume control on tv does not work.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
5/13/2016 3:56:42 PM • Panasonic... • Answered on May 13, 2016
0answers
What size are the screw holes for a Panasonic TH-37PX60U
To know more, you have to download the service manual to this set. http://electronicshelponline.blogspot.com/
7/23/2014 7:52:14 AM • Panasonic... • Answered on Jul 23, 2014
We have a Pensonic led 3216 led cut, when we try to open it the screen is all black how to fix it? how to do a reset n the tv
Not totally sure what your asking but I think your saying your LED lamps aren't working, if that's the case replace them
10/15/2021 10:33:14 PM • Panasonic TH... • Answered on Oct 15, 2021
0answers
Tx-p42ut50b
Be the first to answer 6/5/2014 12:19:19 PM • Panasonic TH... • Posted on Jun 05, 2014Be the first to answer
Random Side Panel Inputs
You either have a bad Main board or simply a bad touch control button in other word one of your side buttons is defective and it is blocking any other signal to the main board, but usually its a bad main board. In some cases ther is a FIRMWARE update from Panasonic, you may want to call Panasonic or check there website for any type of FIRMWArE UPDATE.
5/10/2014 11:34:00 PM • Panasonic TH... • Answered on May 10, 2014
0answers
Hdmi problem
Be the first to answer 4/23/2014 3:36:40 AM • Panasonic TH... • Posted on Apr 23, 2014Be the first to answer
0answers
0answers
Panasonic Th-42px25u/p 42-inch High-definition Plasma Tv Logo
8 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
TH Panasonic
  • TH Panasonic
Most Popular Question
volume control stops working tried
  • Televison & Video
