20 Most Recent
Cnet (CWR-854) Wireless Router (cwr854) Questions & Answers
Cannot accessroutercontrolpanel
well....you entering the WRONG IP address.....from your manual :3 Configuring this Wireless-G Router In this chapter, it describes how to use the web management tool, a web browser-based utility that allows you to remotely configure and manage this Wireless-G Router. Open your Web browser and type the IP address "http://192.168.1.254" and press <ENTER>. Enter the User name and Password when prompted, the default User name is "root", and thedefault Password is "1234".Tallon41
I can't reset my cwr-854 router by pressing the
You
can reset this Wireless Access Point by
clicking on Reset button, and then press OK button to confirm your
decision.
Note: you can also hold down the reset button for more than 10 seconds to reset its
default settings back to factory default.
If the reset doesnt work turn off router then on again first, but if the reset doesnt work, the router may need to be replaced.
I cant install my cnet wireless g router cwr-854
you should contact your internet provider for professional advice. it's most likely free and faster than asking nerds on the internet who doesn't know anything about your specific router-model ;)
cheers
Does CNet Wireless-G Router CWR-854
It should work with this 4 year old firmware as technically it the wireless network that connects to the router,as this does not matter on what platform it is running either a windows or linux etc,so it should work.
I have a new laptop
Please check the status of the internet/DSL light on the router. Also please check the connections if you have done it right. The internet cable should go into the WAN port behind the router.If you want to connect the router to your PC as well then take a LAN cable, connect it to one of the LAN ports behind the router and connect it to your PC. If you have done all this right and still have problems, then it may be configuration issue. Please let me know if this is the case so that we can re-configure the router.
Regards,
Sai.
Lag Spikes
Well, sounds like what you need is QoS (Quality of Service) on your router. It is a system that some routers have that will prioritize some traffic over others.
I have looked over the manual for your router and it does not seem to have that feature. The built in QoS of windows apparently does not work to well either.
Sorry, but it looks like you might have to try to get another router.
CNET CWR-854 Wireless G problem.
hello!
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
What is remote access server?
A server that is dedicated to handling users that are not on a LAN but need remote access . The remote access server allows users to access files and print on the LAN from a remote location.
No tengo el disco de instalacion
Me dieron un router inal?mbrico -g serie CWR-854v pero no tengo el cd de instalaci?n q me podr?a ayudar mi correo electronico es torigallo_123hotmail.com si alguien tiene este mismo router si podria ayudarme con el cd de intalacion q en las pajinas no consigo para descargarlo
