20 Most Recent
Cnet Wireless-G CAR-854 Router (CAR854) Questions & Answers
Ip for cnet car-854 modem
If you're looking for the IP address of this router , By default the IP address should be set to 192.168.62. , and you can access the router setup page by typing that IP address on your address bar.
But if you really want to make sure about your router's IP address do these using a computer connected to that router.
Click Start > Programs > Accessories > Command prompt it will open the black window and from there type IPCONFIG and hit enter just look for Default gateway that is your router's IP address.
Looking for default IP adress for my cnet car 854
1. Connect your router to your computer via ethernet cable
2. Now we will check the IP Address
Windows XP
1. Click "Start"
2. Click "Run"
3. Type "cmd" without quotes
4. On the black screen type "ipconfig" without quotes
5. Look for the default gateway, whatever IP Address you can see there is the default IP Address of your router
Windows Vista
1. Click "Pearl button" (Start button in XP)
2. Click "Start Search"
5. Right click the black icon up at the top of the window
6. Click on "Run as administrator"
7. Click on "Continue"
8. On the black screen type "ipconfig" without quotes
9. Look for the default gateway, whatever IP Address you can see there is the default IP Address of your router
I hope this helps you.
IP adress
Please write what do you want? If you asking for the default accessing IP address of router then connect the router with your PC ,run CMD and type ipconfig...see what is the default gateway address, that is the IP address of your router. type that in your browser and you can access the router page ...
Thanks for joining us.
Have a nice day.
All plugged in and was working, just stopped.
hi,
it seems that the wireless network connection is not working.
you will need to check the wireless connection settings on the router, you will need to access the router set up interface.
Also you wil need to check the wireless connection on the laptops.
It is very simple .
Click Here for more info
Good Morning , I am new 8) but wise. I have a Cnet
If the easy setup option is not available, you will have to configure your router manually. General instructions for setting up a home router are available here:
http://compnetworking.about.com/od/homenetworking/ht/routerconfigure.htm
What is remote access server?
A server that is dedicated to handling users that are not on a LAN but need remote access . The remote access server allows users to access files and print on the LAN from a remote location.
No tengo el disco de instalacion
Me dieron un router inal?mbrico -g serie CWR-854v pero no tengo el cd de instalaci?n q me podr?a ayudar mi correo electronico es torigallo_123hotmail.com si alguien tiene este mismo router si podria ayudarme con el cd de intalacion q en las pajinas no consigo para descargarlo
Cnet cgs-2400 fan replacement
it's really not worth the trouble of replacing the fan, but if you really want to fix it then you can just expose the motherboard and use a regular fan on it's highest settings (make sure nothing can mess with the router, little kids and pets might play with it).
Give password
The router password can be change if you try inputting 192.168.0.1 in the command line of the Internet Explorer.
You may need another set of numbers if the router is other than a Cisco product. It could be 192.186.1.1 or 192.168.1.0 also.
You did not specify what Router you were using?
