20 Most Recent
Sportcraft Tx 4.9 Model 4041 B Walking Belt Questions & Answers
How do I tighten a slipping belt
My tread mill has a bolt on each side at the rear end that I put a hex key in and turn to tighten. Do both sides the same to keep the tread even on the track. Don't over tighten. I have a different make but most operate the same.
The threadmill stops when i step on the decke. Why?
1) this hapeen has a protection to the electronic system, the machine keep safe the electronic soft and hardware.producing a shut down.Lube the DECK BELT, inmediately.2) LUBE the rollers bearing too very well3) TEST the input voltage motor, if there are the motor need repair.4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.God bless you
When you start the treadmill the speed moves up by itself
Dear Sir:This is bad adjustmente from speed sensor, clean, and tigh the connector very well, maybe can be faulty s. sensor.By that reason RUN inmediately the software calibration for diagnose, troubleshooting, and fix it.sincerely. God bless you
Treadmii belt
Dear Sir:Adjust according with the instruction manual, see the diagram attached.if you do not have i. manual go for free download www. manualsonline.com or www. iconservice. com .sincerely. God bless you.
