20 Most Recent
HP ProBook 4430s Notebook Questions & Answers
My screen isnt filing whole screen
Do you notice the same appearance for other applications? If not, you browser settings need adjustments. Check for settings from the control button [ 3 dashes ] on the upper right hand side for Chrome and a gear icon on MS Internet Explorer. Adjust the zoom value to your preference (or you may also reset all settings to its defaults).
Good luck happy browsing.
Overheating
please check in bios the CPU temperature if its 36 degree its fine else remove cabin and clean the fan with brush or use blower to clean
Opens new window when you click on a browser link
You may try to attach a USB Wireless Mouse and Keyboard set and bypass the system you are currently using. If it is a Keyboard only problem, try a USB independent keyboard and again bypass the computers unit to see if the problem still exisists.
Where is cmos battery
CMOS (complementary metal-oxide-semiconductor) is the term usually used to describe the small amount of memory on a computer
motherboard that stores the Bios settings.
Its on the motherboard always.
Motherboard
your integrated gpu may have gone bad. the quick way to test it is to use the vga cable and hook up to an external display.
Webcam is not detected
visit
www.hp.com choose "drivers and software", enter your model number and select your notebook and operating system (ie windows 7),scroll down and you will find a universal camera driver follow instructions to download and install.
Hp probook 4430s overheat
there may be dust building up in the vents of your computer, and that restricts the air-flow to cool it. carefully use a hose vac and small attatchment to vac vents. also, I set my laptop on a hard surface with 'jenga' blocks under it to keep an air space under my laptop to provide better air flow
Erratic screen resolution
On the Desktop, in a open space, right click and choose Screen Resolution, adjust to 1366x786 click on Apply.
ESET Nod 32 antivirus serial key
But Which Version ?I Have Send To Some Key Try :-Username: EAV-51526916Password: kpvr48kr5nLicenza Valida fino: 13/03/2017Thanks And Regards,Piyush Gohil
Bootmgr image is corrupt the system cannot boot
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
