20 Most Recent
Sharp AQUOS LC-C4654U 46" LCD TV Questions & Answers
I have a sharp aquos lc-c4677un its not turning on
How are the power and opc lights blinking?
Do they blink simultaneously or does one blink then the other?
How many time do they blink per second?
Also have you had it fixed yet? and if so what was done?
I had a similar problem with my set.
Lc46d43v will not power up
Do you have a power light? If so is it solid or blinking? what color is the light and what happens when you press power hear any click, or other sound?
Sharp Aquos LC-C4654U
The TV blacks
Good day!!! That problem is cause of faulty capacitors on the power supply... just look at the actual image of it through visual check if the capacitors look like leak/bulged on top you need to replace it to end that problem... hope it helps... \thanks for using fixya..
Sharp TV LC60LE745U the screen remained black and an arrow on the bottom of the TV stay blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
