20 Most Recent
Crate FlexWave FW120 Guitar Amp Combo w DSP, 120W Questions & Answers
I am looking for the proper fuse needed for this amp. I keep purchasing the wrong ones
The fuse rating should be printed on the panet right by the fuse holder. If there's still a question about values, you're best bet is to contact Crate customer service.
Here's the link-
http://www.crateamps.com/support
However, if you're meaning that you keep blowing fuses and therefor think you're instaslling the wrong value, you may have a short in the amp that's casuseing the fuses to blow. In that case, it needs to go to the shop. If you're not a tech, don't poke around inside it. You can make the problem worse, or even get a nasty shock.
Buzz across all channels in crate rfx120
I also have this issue. Same crate combo amp. There is a loud buzz emitted only when there is a cable plugged in. Cables and instruments checked good, only possible issue is inside the input of the amp. Popped it open, solders and connections were intact and appeared solid. Anyone have a guess as to why this is happening?
11/25/2022 6:21:12 AM •
Crate Music
Answered
on Nov 25, 2022
Schematic crate g60xl
https://www.google.com/search?q=Schematic+crate+g60xl&oq=Schematic+crate+g60xl&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
12/1/2020 11:32:44 AM •
Crate Music
Answered
on Dec 01, 2020
Crate GX 40- C schematic
Power supply capacitors failed. This is a common problem with 1990's crates, also the power on "POP".
5/2/2019 7:09:02 PM •
Crate Music
Answered
on May 02, 2019
