20 Most Recent Adobe Systems Incorporated Illustrator CS4 Questions & Answers
2answers
Insufficient Memory in Adobe Illustrator
It is obvious your scratch disk does not have enough space. I would say that truth about the memory problem is the Very Critical Memory Bug that comes with CS4. You can try to disable all the apps that are running at the same time, but the problem can be still here. Installing of a current AI version might help. Also try to save a TIF of the image in Photoshop, it could be a quick fix to the problem. Or reduced the pixels number. If nothing helps, use a special software that is able to recover it. There are a lot of on network, but unfortunately not all of them are so good. Try Recovery Toolbox for Illustrator https://illustrator.recoverytoolbox.com/ Oh, also i've remembered one method: Unlock all the layers and 'select all' and 'copy'. Than create a new doc and paste your image in there. Save the document with a new name.
4/4/2015 8:39:15 AM • Adobe Systems... • Answered on Apr 04, 2015
3answers
Adobe audition serial key please
am pascal Mbarubukeye as seen on my profile, i would like to ask for supporting me to offer serisl number of adobe audition 1.5, because what i have was corrupted. please help me i begg!
3/24/2024 8:37:43 AM • Adobe Computers... • Answered on Mar 24, 2024
Adobe audition serial number 3.0
You were supplied with the serial number on the install disc or on your purchase invoice.
3/21/2024 1:03:35 PM • Adobe Computers... • Answered on Mar 21, 2024
To instul or download adobe flash player please help
It's really easy, Just search it on Google and you will get 100's of blogs & videos to download and set up adobe flash player.
3/19/2024 6:05:00 AM • Adobe Computers... • Answered on Mar 19, 2024
ADOBE AUDITION 1.5 SERIAL NUMBER
You have the serial number as it is supplied when you purchase it.
3/16/2024 7:13:50 PM • Adobe Computers... • Answered on Mar 16, 2024
3answers
Photoshop cs3 extended authorization code
You need to call adobe support and get the activation code
2/20/2024 4:25:16 AM • Adobe Computers... • Answered on Feb 20, 2024
I need an authorization code for my Adobe Illustrator CS2. Serial Number is: 1034-1954-1891-5785-4998-0841 Activation number is: 5136-2709 - 1286-0197-8761-1539-5256 Activation Type is Normal 17:17.
Nothing to do with Fixya, we aren't Adobe. It says here that Activation Servers are finished for it in 2013. Help in the forum.
Need authorization code for CS2
Adobe Community https://community.adobe.com > ... > Discussions Dec 7, 2018 - Solved: I've had to reinstall all applications after restoring Win10, and I have my CS2 Standard disks; installation itself went fine. 11 answers · Top answer: See here and use the new serial number you will be provided : Download Adobe Acrobat 7 and ...
Adobe Illustrator CS2 activation
Adobe Community https://community.adobe.com > Illustrator > Discussions May 13, 2016 - There is no longer any authorization code server. Adobe just turned it off, because apparently they just can. And they provided a replacement, ... 11 answers · Top answer: CS2 + Acrobat 7 + Audition 3 (AND EARLIER) Activation Server is gone, so read below http://helpx.ad ...
Activation Authorization Code
Adobe Community https://community.adobe.com > ... > Discussions Apr 21, 2020 - Hi RSA_dvertising, CS2 is no longer a supported product and the activation servers had to be shutdown in 2013. Replacement ..
12/23/2023 5:44:05 AM • Adobe Computers... • Answered on Dec 23, 2023
2answers
Serial code: 1325-1413-3017-0892-3878-8629
You should never post such codes on an open forum, others may use it against your wishes.
If you call Adobe, they will straighten out the issue for you if your codes are legitimately paid for.
12/21/2023 3:09:24 PM • Adobe Computers... • Answered on Dec 21, 2023
Adobe Cloud. Can it be used for image backup.
Apparently not recommended. It is for Sharing Files and not meant to be a back up. https://www.google.com/search?q=can+adobe+cloud+be+used+for+image+backup .. ..
12/8/2023 5:48:56 AM • Adobe Computers... • Answered on Dec 08, 2023
I need authorizartion code for adobe photoshop cs3
The code is supplied when you purchase this software. Don't ripp it off!
11/26/2023 11:14:46 AM • Adobe Computers... • Answered on Nov 26, 2023
3answers
I want authorization code
well u need the keygen bcoz each serial number has its own unique authorization code on the basis of which an AUTHORIZATION CODE is generated. u may find it here http://rapidlibrary.com/index.php?q=adobe+photoshop+cs3+keygen
10/23/2023 6:49:26 PM • Adobe Computers... • Answered on Oct 23, 2023
2answers
I need authorization for photoshop cs3, i have s/n and a/n
Register your purchase with Adobe, they'll give you the key.
3/6/2023 10:26:17 AM • Adobe Computers... • Answered on Mar 06, 2023
2answers
Activation type 159:41
To help you out. Get yourself a little note book and write all pass words and codes and your computer information down in it and keep the note book in a drawer where you know where it is kept. When you change any information cross it out of your note book and put your new one in.Saves a lot of headaches when trying to remember .
1/4/2023 10:14:40 PM • Adobe Computers... • Answered on Jan 04, 2023
I need Authorization code Phon for Adobe photoshop cs3
Contact with Adobe will do you no good. The activation servers for this product are shut down. Even if you had the serial for it, it will not activate. Adobe stopped selling this in 2008. If you acquired it, you have an unlicensed product with no access to an activation server. I cannot supply guidance to any workaround if I found such as Fixya does not offer "cracking" services.
12/29/2022 7:06:27 AM • Adobe Computers... • Answered on Dec 29, 2022
2answers
Authorization code of Adobe Photoshop CS
My serial number: 1045-1090-6246-8353-3166-2968activation number:5161-9399-8946-3178-9348-6374-4063activation type: Normal: 194:13my e-mail : [email protected] plz give me Authorization code
11/24/2022 5:57:52 PM • Adobe Computers... • Answered on Nov 24, 2022
My serial number: 1330-1782-4594-0776-8926-5081 activation code:
Hello
Photoshop cs3
Serial Number 1326-0019-7846-1747-7692-8500
Activation Number 6761-5904-6625-1779-5844-7676-0486-6623
Activation Type:Repair
Need Authorization Code please!!!!
send it to: [email protected]
thank you!!!!!!!
11/18/2022 6:30:03 PM • Adobe Computers... • Answered on Nov 18, 2022
2answers
Hi i want an authorization
plz help me serial number-1330-1564-0603-9333-0603-5060 activation number-4309-6265-2467-6843-4212-7398-4895 plz snt me authorization code snd me [email protected]
10/9/2022 5:50:32 PM • Adobe Computers... • Answered on Oct 09, 2022
Adobe Systems Incorporated Illustrator CS4 Logo
2 questions posted
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Adobe Computers & Internet
Most Popular Question
insufficient memory in adobe illustrator
  • Computers & Internet
