20 Most Recent
Nintendo DSi XL Console Questions & Answers
I forgot my pin so can ya tell me the master key
Hi tuhulu,
Attached is a website to get a bypass code for your DSi -
http://wii.marcansoft.com/parental.psp
Although, it only indicates Wii, it also works for Nintendo DSi consoles.
Just key in your Inquiry number and date and then just use the unlock code from the website to unlock your console.
Please note that the date that you enter into the website should be the same date that reflects on your Dsi console.
I hope this trick helps you too. Let me know if it works for you.
Cheers !
Master key for nintendo dsi xl without calling nintendo
Nintendo DS Browser Failsafe Mode:Ok, you may need help to do this, as everywhere I have looked has said it's pretty tough to do alone (one person said they had to hold the stylus in their mouth).When you go to launch the browser, hold L, R, Up, X, B, and select Enter Failsafe mode to clear bookmarks and reset to factory settings (as well as eliminating the password).This key combination is the first thing the system and browser checks for, so you have to be holding it from the start of the boot-up. So turn the unit off, press the buttons (and hold them) then turn it on, continuing to hold them while tapping A to launch the browser from the menu. Continue holding until you get the failsafe screen or asked for the password (in which case you need to try again).
Dsi xl message 0000fe00
Some users have been able to solve this problem by resetting the
system. To do so, hold down every button while the system is on except
the D-Pad and power buttons. Otherwise if the problem continues you'll
likely need to send in your system for repair. I'm sure videogame911.com can help you they were great with my repairs and at a great price.
My dsi wont turn off
I had this same problem with a white DSi. It would power up no problem, but would not shut off using the button, regardless as to how long you held it down. All I did, believe it or not, was take the battery out and put it back in. Turns on and off like a charm now.
Internet
having problems connecting to the internet
