20 Most Recent
Kenwood KAC-7201 Car Audio Amplifier Questions & Answers
Keeps blowing fuse when remote
if it is blowing fuses you probably have a blown transistor or shorted component inside the amp. a transistor can look just fine and still be bad.
What is the value of
depending on condition of the amp for excellent condition it would be around 90 to 125 in good condition you looking at about 60 to 90 in poor condition you are looking at 30 to 60 and in bad condition under 30 .
Loud with one quiet with both
make sure you have seperate power and gound seperate remote wires and if it does have a pass through then use it but i would hook up one at a time make sure they both work if after all this and it dont then your deck may not have enough power coming out of it to power the rca's or use y adapters from the cd player and run 2 sets of rca's.
Amp turns on but no sound from subs?
Check to see if your deck has a sub on/off option in the menu or settings if it don't you may have blown amp chanells or bad RCA preouts on deck or bad RCA in on amp
Comes on and goes out
This is usually caused by heat, but it could also be caused by not having enough power to the amp or a bad ground. Check these first and let me know if you need any further help.
