20 Most Recent Kenwood eXcelon KDC-X759 CD Player Questions & Answers
0answers
Mp919
Be the first to answer 2/3/2014 10:19:54 AM • Kenwood eXcelon... • Posted on Feb 03, 2014Be the first to answer
0answers
I have a KDCX759 it
make sure you have no shorted speakers or speaker wires. also make sure the speakers are actually connected. in fact make sure you even have speakers in the car.
3/14/2011 5:52:52 PM • Kenwood eXcelon... • Answered on Mar 14, 2011
Kenwood excelon kdc-x759 change the code
Try to contact at " [email protected] " and send us details about serial and model radio.
3/1/2011 2:08:47 AM • Kenwood eXcelon... • Answered on Mar 01, 2011
The kdc-x759 i have one of the wires that the face
Just do soldering the broken wires. Check the wires colors ( it should same). Get it re insulated using electrical tape and retry your appliance. Regards, Jay
1/23/2011 5:37:13 PM • Kenwood eXcelon... • Answered on Jan 23, 2011
I have a kenwood eXcelon
does the cd seem to be working other than no sound? if so, are you running the audio through an amplifier? if you are using an amplifier, you may be using the antenna remote wire (blue) instead of the amp remote wire (blue/white stripe) to turn the amp on. when using the antenna remote wire it turns off when going to cd mode.
8/13/2010 4:45:44 PM • Kenwood eXcelon... • Answered on Aug 13, 2010
My battery died in my truck today.been 5 years. fo...
you need the security code there is no general. you can contact kenwood with the serial no, they may ask for proof of purchase or ownership
5/23/2010 9:27:54 PM • Kenwood eXcelon... • Answered on May 23, 2010
How to decode a KDC-X759
you need the remote to do this and the default code from kenwood 1-800-kenwood
11/30/2008 4:40:48 PM • Kenwood eXcelon... • Answered on Nov 30, 2008
Subwoofer
Check your wiring. Sounds like you either have a ground wire issue or a have wires crossed.
12/31/2007 10:53:43 PM • Kenwood eXcelon... • Answered on Dec 31, 2007
Kenwood Car Audio system model no. KDC-X8529
Mnay things can stop a CD player from reading.... Try cleaning the LASER LENS in the unit(you may have to remove it from the car) with a cotton wool bud soaked in Windex glass cleaner. Then use a second (fresh, dry, and clean) cotton bud to remove any residue film(left from your cleaning procedure). If this does not work, then the unit may need some detailed diagnostic work done to determine what is wrong, or if a laser replacement is needed. REMEMBER Repairs are worthwhile, only if yo have a good tech!!
12/28/2007 10:12:32 AM • Kenwood eXcelon... • Answered on Dec 28, 2007
Security problem
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
12/14/2007 6:02:56 AM • Kenwood eXcelon... • Answered on Dec 14, 2007
Car audio problem
Type 1
Type 2
Type 3
12/14/2007 6:01:59 AM • Kenwood eXcelon... • Answered on Dec 14, 2007
My kenwood kdc-u2159b display call n no sound out
Me radio kdc2159b is displaying the ward call,how do i remove it
4/14/2024 10:44:35 AM • Kenwood Car... • Answered on Apr 14, 2024
Reset a Kenwood 8070 without a remote?
To reset a Kenwood 8070 receiver without a remote, you typically need to locate the reset button on the device itself. This button is often small and recessed, so you may need a paperclip or a similar tool to press it. Consult the user manual or look for the reset button near the power or input/output ports on the receiver. Once located, press and hold the reset button for a few seconds until you see the receiver reset. Keep in mind that this process may vary slightly depending on the specific model of the Kenwood 8070 receiver.
3/6/2024 3:50:24 AM • Kenwood Car... • Answered on Mar 06, 2024
KDC-138 CD PLAYER/RECEIVER. What does code E-004 indicate?
Kenwood KDC-138 Instruction Manual [Page 18]
ManualsLib https://www.manualslib.com > ... > Instruction manual If the "E-99". code does not disappear, consult your. nearest service center. IN (Blink):. The CD player section is not operating. properly. ? Reinsert the CD.
My Kenwood KDC-d301 is giving me a E-4 error message ...
JustAnswer https://www.justanswer.com > car-electronics Aug 9, 2010 - Hello, The issue is most likely that the laser lens in the CD player itself is dirty, and not the disc. It may have been initially caused by a ... 1 answer · Top answer: You need the Kenwood radio keys that came with the unit to slide it out of the dash. It sounds ... Missing: 138 ‎' Show results with: 138
I have a KDC 138. It is stuck on OCER and will not reset.
JustAnswer https://www.justanswer.com > car-electronics > 5lw8u-... Sep 27, 2011 - This actually is DCER - you have a blown speaker. The radio is sensing a ground on the speaker circuit. Check that and let me know. If you leave ... 1 answer · Top answer: Thanks for stopping by: This actually is DCER - you have a blown speaker. The radio is sensing ... Missing: E- ‎' Show results with: E-
Cd Player Unit - Kenwood KDC-138/138CR Service ...
ManualsLib https://www.manualslib.com > ... > Service manual Kenwood KDC-138/138CR Manual Online: components description, Electric Unit, Switch Unit, Cd Player Unit. Controls Fm/Am Tuner, The Changer, Cd Mechanism, ...
2/16/2024 6:44:56 PM • Kenwood Car... • Answered on Feb 16, 2024
How to power supply of kCSWA900 Kenwood sub whooper power supply 10 pin
Take a look at this manual diagram. https://www.manualslib.com/manual/359815/Kenwood-Ksc-Sw10.html?page=5#manual Given the above is not your model, at least it shows the 10 pin. Ironically, below I offer a diagram of your model. The irony comes in the fact that the diagram appears labeled in Japanese But if you compare the two diagrams, maybe something will make sense from the one with the English labels. Otherwise, you might fire off a query to Kenwood customer support. https://www.manualscenter.com/manuals/kenwood/kscsw900-owner-manual.html Here is a 10 pin harness compatible with the subwoofer. Kenwood Subwoofer Amp KSC Wa100 Wa80 Sw10 10 Pin Harness for sale online ' eBay I don't have any information on how to power supply a kCSWA900 Kenwood subwoofer. However, I can tell you that the Kenwood KSC-SW10 compact powered subwoofer has a built-in amplifier with a 38 watts RMS power and a wired remote for control over volume level, variable low-pass crossover (50-120 Hz), and selectable phase control (0°, 180°) . The subwoofer comes with a power/ground wiring harness and preamp (RCA) and speaker-level inputs .
1/26/2024 3:58:54 AM • Kenwood Car... • Answered on Jan 26, 2024
2answers
Kenwood eXcelon KDC-X759 CD Player Logo
Popular Tags
14 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
subwoofer
  • Car Audio & Video
