20 Most Recent
Kenwood Sirius KDC-MP425 CD Player Questions & Answers
Unlocking radio
I have this problem almost everytime I have to do it. It's such a rare occasion. If I remember correctly, just press and hold the key that moves you to the next number... the >>| key, I believe. After a couple seconds it'll beep & open up (provided you have the correct code).
Kdc mp425 only has sound in tuner mode
If you are using an amplifier, make sure you are using the blue/white wire to turn it on. The blue wire is power antenna remote turn on and turns off when leaving tuner mode.
My desk works great, expect
It sounds like the contacts are getting weak or the contacts are dirty... Take off the face and clean the contacts with alcohol. If that dosen't help then take a paper clip and gently bend the pins up. Be careful not to break the pins.
Kenwood Kdc-mp425 will not switch to Aux.
Apparently, this auxiliary input only works for a Kenwood CD changer or a sirius radio connection. At least that is my conclusion after finding the same problem. Let me know if you figured anything out on this.
Radio codes
you'll need your vin # as well as the radio serial and part # (which will be on the radio) handy then call 1888mitsu2008 they will give you your code free of charge
Peugot 206 car radio needs decoding
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Please your help, o forgot the code security of
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The
procedure to enter your security code differs on various models of
Kenwood car stereos. Here are three of the more common procedures:
Type 1
During
the code request mode, while holding the DISP key depressed, press and
hold the Volume UP or DOWN key for 3 seconds until the "..." display
disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To
enter a letter using your Kenwood remote, press a button once for the
first letter, twice for the second letter, and three times for the
third letter -- then press the Track Up or Next Track key to send the
letter.
To send the letter 'A', press the 2 key once and then
press the Track Up key. To send the letter 'B', press the 2 key twice
and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There
is a reported bug in the security code handling of some Kenwood
stereos. In models with thie bug, the security code is stored
incorrectly. The workaround is to enter the wrong security code.
In
models with this bug, you have to decrement the third character of the
security code by one. If your security code was 1111, you would enter
your security code as 1101. If your security code was 9999, you would
enter 9989.
Want sirius on this
CLICK HERE for your owners manual
Your radio is already Satellite READY - all you need is the Sirius Tuner/antenna.
The model # is
KTC-SR901/902
eBay Auction #1
eBay Auction #2
This is a subscription service - so that is required as well to activate the radio.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
No sound
check all connections-look for blown fuse either inline or at the fusebox-if that all checks out -check speaker wiring for any exposed,nicked or loose connections-if that checks out then make sure that your fader /balance settings are all good. if that doesnt get to the problem ya may want to take it into the shop and get your deck looked at.
Forgot the code...HELP
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
