20 Most Recent Sony KV-27XBR45 27" TV Questions & Answers
WHEN i TURN THIS TV ON, ALL I GET IS A W
A bright white line across the middle of the screen indicates vertical sweep output failure. Check and repalce dmaged component/s in the vertical output section circuit. Check for any loose solder terminals around the the vertical output section circuit. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
11/11/2012 11:18:39 AM • Sony KV-27XBR45... • Answered on Nov 11, 2012
2answers
PIP for Sony KV-27XBR45 television trouble shooting
If you have the original remote for this TV on the pip menu (left side slider on remote all the way up) there is a pip off button. If you unplug the unit long enough it should go back to normal. If you go into demo mode and then exit mode you will again be out of the pip. With out the original remote you cannot easily turn pip off.
7/5/2011 4:10:11 AM • Sony KV-27XBR45... • Answered on Jul 05, 2011
Just got home. Roof leaked. Water in back of TV.
Unplug the set and give it a shot. Nothing to lose at this point. Considering the age of the set, it's not worth getting it fixed anyway.
4/27/2010 4:30:23 PM • Sony KV-27XBR45... • Answered on Apr 27, 2010
Don't have original remote for Sony tv, and can
Here a website to get the original remotes.1-800-Remotes Factory original.To buy exact remotes or very close to the original.No other way,tv control on the front of the tv don't have functions to work for PIP.
11/3/2009 11:35:30 PM • Sony KV-27XBR45... • Answered on Nov 03, 2009
SONY KLV-S26 10E ( SOUND TROUBLE)
check the RCA jacks it could be defective..
3/4/2009 9:44:32 PM • Sony KV-27XBR45... • Answered on Mar 04, 2009
Sound trouble
If you have a cell phone or wireless internet this may cause interference. If you have any of these close them out and see if it still does the sound.
2/15/2009 10:21:51 PM • Sony KV-27XBR45... • Answered on Feb 15, 2009
SONY KV-27XBR45 slighly out of focus
If you open up the back and locate hte fluback transformer (part with large red wire coming out of the top), you should see two controls on that tramsformer. One is the screen control which will control the overall brightness of the picture and the other (bottom I think) is a focus control. It may be marked on the transformer itself as well. Turn that control slightly while watching the set. This should resolve the problem.
Dan
7/8/2008 8:06:53 PM • Sony KV-27XBR45... • Answered on Jul 08, 2008
SONY KV-27XBR45 stays in stand by mode, trying to go on but fails
check vertical i.c.
3/17/2008 9:19:14 PM • Sony KV-27XBR45... • Answered on Mar 17, 2008
Sony kv32v15, Red screen with fine horizantal lines then shuts off
I would suggest to measure the 200 volt B+ at the CRT socket. If that voltage is found to be low, disconnect the socket from the CRT and measure again. If the voltage reading returns to normal you may have a defective CTR.
Also check for open or defective diode on flyback transformer for the 200 vdc source.
I would also suggest to take all the necessary precautions since you are working in a very high voltage area.
Good Luck.
1/15/2008 7:48:49 PM • Sony KV-27XBR45... • Answered on Jan 15, 2008
Delay to see the picture
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
12/28/2007 11:01:00 PM • Sony KV-27XBR45... • Answered on Dec 28, 2007
TV won't turn on.
Try and tune your remote back into the TV
11/20/2007 2:41:36 AM • Sony KV-27XBR45... • Answered on Nov 20, 2007
Sony 27XBR45 picture blue at first and then later goes to color
Sounds more like bad blue gun in CRT. A tv shop with a
good quality pix tube checker / rejuvenator may give some
temporary help......................T.
Please rate this solution..........
11/14/2007 6:48:26 PM • Sony KV-27XBR45... • Answered on Nov 14, 2007
Adding speakers to the output
You have connected the speakers to the audio line out sockets. These are meant for connection to an amplifier and are not suitable for what you are attempting. If there are no connections on the back of the TV specifically for loudspeakers then you will need to add an amplifier or Home cinema reciever.
10/6/2007 11:46:53 PM • Sony KV-27XBR45... • Answered on Oct 06, 2007
I need the code from my Sony RM Y180 television remote to operate my Sony CD/DVD PLAYER DVP-NS57P please?
Question edited for clarity. This is unlikely to work, although I do see the remote has a VCR/DVD Source button. https://www.amazon.ca/Players-Kv-20Fv300-Kv-27Fa310-Kv-32Fs320-Kv-29Fs120/dp/B0874DLQMP And Sony says it is not programable DVP-NS57P The model is not programmable. https://www.sony.com/electronics/support/remote-control-programming/models/dvp-ns57p https://www.google.com/search?q=sony+dvd+remote+codes You can buy a Copycat remote for the DVD Player if yours is lost. https://www.google.com/search?q=DVP-NS57P+replacement+remote ..
4/22/2024 8:10:05 PM • Sony Televison &... • Answered 3 days ago
My sony tv bravia model klv 32v400A has no picture but the mauns light turns from red to green using the remote. What is the problem please?
This TV is 10 years old and probably requires a service that replaces the backlight invertor or just a power supply issue. Check to see if the light blinks. (That is the fault code and then google the result for more information).
4/21/2024 7:49:57 AM • Sony Televison &... • Answered on Apr 21, 2024
Sony HT-CT260 Home Theater Soundbar. Missing the manual for it?
Question edited for clarity, proper name, fix typo. Manual and Reviews
Manuals for HT-CT260
Sony https://www.sony.ca > electronics > support > product Find instruction manuals and brochures for HT-CT260.
Sony HT-CT260 review: Excellent sound that fits nearly ...
CNET https://www.cnet.com > reviews > sony-ht-ct260-review May 7, 2013 - The Sony HT-CT260 is our go-to budget sound bar pick, with excellent sound quality, built-in Bluetooth, an adaptable design, and no major ... Rating: 8.4/10
Sony HT-CT260 Home Theater Soundbar Review
PCMag https://www.pcmag.com > Reviews > Audio > Speakers Feb 28, 2013 - The Sony HT-CT260 soundbar adds Bluetooth to an already highly capable and modestly-priced two-piece audio system. MSRP $299.99. Pros and cons: Excellent value ? Built-in Bluetooth ? Treble response isn't the clearest ? View full list Rating: 4 · ‎ Review by Will Greenwald · ‎ US$225.00 · ‎ Out of stock ..
4/6/2024 7:46:33 PM • Sony Televison &... • Answered on Apr 06, 2024
Codes for SONY TV on CYBERTEC REMOTE RM-L1107+3??? Pls help!!!
Pano po ireset ang cybertec 8 in 1? Salamat po
3/19/2024 11:52:38 PM • Sony Televison &... • Answered on Mar 19, 2024
Sony older model with side speakers flashes red led after blinking green here a grinding sound when powering on
All questions need 'make model (what is is)' as first 3 words in every question please. Television? Stereo? Sound bar? ICE? The grinding noise makes me think you have a cooling fan issue, in which case the flashing LED would be signaling an overheat situation. You can Google sony model blink codes ..
3/18/2024 7:02:45 PM • Sony Televison &... • Answered on Mar 18, 2024
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
3/7/2024 2:17:41 PM • Sony Televison &... • Answered on Mar 07, 2024
Televison & Video Logo
21 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony kv 27xbr45 slighly out focus
  • Televison & Video
