20 Most Recent
Sony KV-27S46 27" TV Questions & Answers
Sony tv wont turn on, standby light just flashes
check for an open resistor on the power supply, it is actually a fusible resistor, (white) if open, then check the converter, some sets have two separate and some have it as one. it will be on a heat sink on the power supply. if shorted then check for a shorted horizontal output transistor and repair cold solder joints on the horizintal drive transformer which is the real cause of this problem
Can't get the Video 1 symbol off of my TV.
There is a button on the remote labeled display that must be hit to remove the on screen display. You can use any Sony TV remote so you may want to check out GoodWill for a used one. Sony also has a universal available but it may be hard to find, maybe Radio Shack. There is no other way of turning off the OSD.
Power clicks on and red power light flashes but no picture
The problem might come from the fuse inside was blow out. if you have a multimeter then open the rear cover. The fuse lays near the power cord. Take it out and use Ohm meter to check it connectivity. If it is no connectivity meaning the fuse was blow out. Replace a new one with the same value (Ampere and Voltage). If it does have connectivity, the problem needs technician to find out as it relates to many parts on the circuit board.
Sony KV-27S46 tv has no picture, no sound, 4 flash diagnostic.
4 blinks Indicates For Your Exact Model To Replace D606 (P/N 871910818) SCR.
Also Please Don't Take Out Your Anger For Your Broken Device On Me. Sony Knows Of This Problem As It Is Very Very Common So If You Want You Can Call Them And They Most likely Will Have Your Exact Fix.
Up and away
problem in your vertical circuit look for cold solder joints.
Black vertical line on right side (intermitant)
Your problem sounds like the stk type regulator.. Itsnot a really expensive part BUT on a set this old yes you can repair it but also your gonna be repairing it more and more as the capacitors are drying up and the circuit is getting brittle. I wouldnt invest anything in this set. time to make a boat anchor out of it!
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
