20 Most Recent Sony FD Trinitron WEGA KV-34HS510 34" TV Questions & Answers
What is wrong a Sony trinitron kb-34hs510 blinks 7 times has power but no sound and no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
12/17/2014 8:03:11 PM • Sony FD... • Answered on Dec 17, 2014
2answers
Wont turn on. There are 5 and 6 blinking stand by
my sony kv-34hs510 tv wont turn on.ther are 6 and7 blinnking stand by lights.
11/30/2014 2:09:19 AM • Sony FD... • Answered on Nov 30, 2014
Sony TV WEGA wont turn-on. stand by LED
line o/p transformer &transistors are gone .. any service person can replace them
8/4/2014 3:53:16 PM • Sony FD... • Answered on Aug 04, 2014
0answers
3answers
Kv-34hs510 standby light blinks six times over and over
6 blinks is usually the D board
12/21/2013 11:00:04 PM • Sony FD... • Answered on Dec 21, 2013
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
6/26/2013 7:52:14 AM • Sony FD... • Answered on Jun 26, 2013
Can dust cause Sony Trinitron 34" tv to go black and make popping sounds?
Dust rarely affects this kind of set---this model had high voltage problems---and if popping I would unplug it.To be honest this set weighs a ton and is expensive to fix, average repair can be well over 200 dollars.A lot of them now are being retired and replaced with LCD sets etc.
12/23/2012 3:04:13 PM • Sony FD... • Answered on Dec 23, 2012
Four beep flashing
if the set displaying sony also 4 times logic card is defected .if not displaying any thing check the back light of panel
10/9/2012 8:33:12 PM • Sony FD... • Answered on Oct 09, 2012
How do I connect wireless headphones to my sony kv34hs510
Are your headphones blutooth or infra-red? Is your Trinitron Blutooth or infrared enabled to allow you to listen to it thru your headphones? If so, there must be an on/off switch that would actuate the Blutooth or infrared meachanism on the Trinitron itself. Otherwise, you WON'T be able to hear sound.
9/20/2012 4:56:44 AM • Sony FD... • Answered on Sep 20, 2012
My tv shows black screen but has sound
1) the main problem is lack of Raster 2) see the block diagram, test Video Detector, the transformer or flyback, horizontal output transistor, rectifier HV,,God blesss hyou9_18_2012_4_33_28_am.gif
9/18/2012 4:34:45 AM • Sony FD... • Answered on Sep 18, 2012
Screen went green on sony tv
Check the video output section circuit for any loose soldering or component failure. Check the voltage at the green cathode of the picture tube. Can be measured by using a multimeter. At present, this voltage will be lower than other tow cathode voltages. In most cases, the cause for this fault is found to be with loose solder terminals itself. Check all the solder terminals at the video output stage printed circuit board. You can locate this board at the picture tube base itself. Will be plugged to the back of the picture tube neck. A rectangular board. Normally, it will be very difficult to detect loose solder points, as they might be microscopically small to detect by ***** eye. So it is recommended to re solder all the suspected solder terminals there, by applying little more fresh solder, without making any solder bridge short in between adjacent solder terminals. This must solve the problem you faces with your TV
7/23/2012 3:41:33 PM • Sony FD... • Answered on Jul 23, 2012
Sony tv not coming on
if no any power light indicator that blinks or lit, the cause it could be the primary power supply failed or the horizontal deflection circuit has shorted component. you must need to trouble shoot those circuit to fix the problem. however if you think you can not do it with your own, just leave it to the trained tv technician. at least you have an idea what to expect when you decide to hire for somebody to fix the problem.hope this can helped.
7/22/2012 7:09:24 AM • Sony FD... • Answered on Jul 22, 2012
Sony KV-34HS510 won't turn on
The power supply regulator section will have the fault.
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Site is listed in Google, and you can locate it either at the bottom part of first search page, or at the top of second page.
Click on associated ads too. Sometimes, it might help you.
6/1/2012 4:34:02 PM • Sony FD... • Answered on Jun 01, 2012
Sony fd trinitron wega kv34hs510
The set may have a self check mode or error buffer--most of these that do with the set turned off: Display, 5, vol. down and then power.If it has the buffer a box will appear in middle of screen with several items listed-----------all should have a 0 to the right of them---a number indicates a error detected and noted.If no error found or no display for that contact Sony for the reset code which usually is gained by going into tech menu (different from error menu) and with remote pressing 7 and enter---this does a hard reset and returns set to all factory defaults--if that did not cure it you have a interesting trouble...........
3/19/2012 7:01:05 PM • Sony FD... • Answered on Mar 19, 2012
Red tint
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com Common Problem #1) Convergence has gone outProjection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem. Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems. 7859b01.jpge87380c.jpg 69189a5.pngSOLUTION #1What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.Common Problem #2) CRT Fluid is CloudyProjection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images. Picture of a set that needs the fluid changed.578ba6c.jpg TV set after fluid change65af323.jpg 69189a5.pngSOLUTIONWhat you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
3/9/2012 3:21:52 AM • Sony FD... • Answered on Mar 09, 2012
Turned off tv last night.went
replace two chips, cost you about $10.00
7/11/2011 4:19:58 PM • Sony FD... • Answered on Jul 11, 2011
2answers
Sony KV-34HS510 blink codes
I would question that diagnosis, Did you get it online somewhere or did you have a tech check your B+ voltages ?
6 blinks is almost always caused by 2 chips on the "D board", they are both marked MCZ3001D you can order them here if you are a consumer not a tech 800-575-9833. Not to say that the jungle IC & those 2 caps couldn`t cause a dead set symptom but these 2 IC`s are notorious for the 6 blink code, I have personally fixed approx. 10 sony sets with the 6 blink code with those IC`s, hope this helps
7/11/2011 4:13:28 PM • Sony FD... • Answered on Jul 11, 2011
TV goes to standby What
HI:
Count the number of red blinks on the power led, if it is 6 or 7 blinks then pauses and then does the same amount of blinks then ther is a problem with 2 IC's that needs replacing on the D board. To repair this including parts should not cost more then $150.00.
7/5/2011 10:31:58 PM • Sony FD... • Answered on Jul 05, 2011
TV will not power on.
The Standby light flashing that you see is the built in diagnostic program signalling an issue. This particular one means that the D board is not getting the 15 volts it needs, and normally IC5004 is causing the issue. It has been awhile since I dealt with this repair and I therefore have no idea what it will cost you to have it resolved.
If you have some experience working with TV's you might want to take a run at fixing the issue. You would have to ensure you have the tools you need as well as a copy of the service manual, which you can purchase or download of the Internet. I would not advise trying the repair yourself if you have no experience with the inside of a TV. There are lethal voltages and amps inside that must be dealt with in the correct way so that it is safe to work inside the TV.
I would suggest calling your area Sony repair shops, let them know what the flashing code is and what it is signifying, and then asking them for a quote to fix the issue. As most electronic repair center charge from $85-125.00 an hour for labor I would get an estimate and then decide if it is worth fixing, or would it be less expensive to buy a new TV.
6/29/2011 1:37:51 AM • Sony FD... • Answered on Jun 29, 2011
Sony FD Trinitron WEGA KV-34HS510 34" TV Logo
80 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
dust cause sony trinitron 34 tv go
  • Televison & Video
