20 Most Recent
Sony FD Trinitron WEGA KV-24FS100 24" TV Questions & Answers
Sony tv black screen
Repairing a TV set is actually a skilled work. If you're not sound in electronics, make sure, that you can't do it; especially to Sony sets. If the set switches ON; with audio output OK, and there is no Video, surely the fault should be with its horizontal scan output section circuit. Check that circuit for fault. To get more details,
11/22/2013 8:02:06 AM •
Sony FD...
Answered
on Nov 22, 2013
Tv wont turn on and the stand by blinks 2 times pulse 2 times sony Trintron KV-24FS100
- Two
blinks - B+ over current protection (OCP), unit goes to the standby mode
then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits. This is the fault. There is over voltage from the voltage regulator section inside. You have to check out the reason for that. In most cased, the will be due to some loose solder terminals at this section.
Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. It will make
search easy. There are more than 1300 posts to different brand TVs now. Pull up
older posts there. Check the site, and see whether it can help you.
11/25/2012 6:40:00 AM •
Sony FD...
Answered
on Nov 25, 2012
My remote worked fine, but suddenly won't work
Could be the IR receiver in the TV.
Make sure nothing is in front of the TV that would block the IR from receiving commands from the remote, I've seen customers put VHS tapes on the front of their TV that caused the remote to not to work.
Good luck
N Sabre
11/9/2009 3:54:35 AM •
Sony FD...
Answered
on Nov 09, 2009
My sony triniton tv won't turn on. The standby red
HI. this may be a fly back situation. this is a transformer that is located on the power board section of your set. This device stores and, distributes the necessary AC current needed for proper CRT performance. There is also a horizontal deflection chip that will shut off the transformer if it becomes unstable as well.
I recommend checking the Horizontal deflection chip for damage. if this chip is in good condition, replace the HV Fly back transformer.
6/25/2009 10:38:50 PM •
Sony FD...
Answered
on Jun 25, 2009
Vertically short picture
There is a bad capacitor in the vertical circuit. Look for caps in the same circuit and either check or change them. If hte vertical IC is listed as IC301 for example, the caps in the same circuit will be marked C3xx. These are circuit designations that are printed on the board. Look for caps with values of either 47ufd or 100ufd. These are the most common ones to fail.
Keep us posted,
Dan
4/1/2009 11:43:09 PM •
Sony FD...
Answered
on Apr 01, 2009
SHORT PICTURE
it could be a setting in the picture menu it sounds like it is set to 4:3 there should be an adjustment in the picture menu on your set hope this helps regards Jim
3/31/2009 11:39:07 PM •
Sony FD...
Answered
on Mar 31, 2009
Acer monitor
try adjusting the vertical width on tour menu button hope this helps regards Jim
3/31/2009 11:07:04 PM •
Sony FD...
Answered
on Mar 31, 2009
