20 Most Recent
Sony VAIO PCG-7181L, PCG-7182L, PCG-7183L, PCG-7184L, PCG-7185L Series Laptop Auto Car Adapter (C1975SUE3250603B87) Questions & Answers
Sony vaio lapto black screen
Please check that they have any LED blinking. If it not blinking it is hardware issue. need to contact local tech. if it blinking. Reboot the computer and taping F10 button while you rebooting the computer and run system recovery and follow by the steps.
6/1/2019 8:36:01 PM •
Sony VAIO...
Answered
on Jun 01, 2019
Connect camera to skpye
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X
right click to reinstall drivers or update driver W7
click start control panel administrive tools computer management device manager scroll down image devices you could see a yellow question mark?
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
also during a video call at the top of your screen you will see an option to for a video call using yahoo messenger this might vary if you are using another messenger service
open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment
click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings
Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick also
select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
10/30/2012 2:53:15 AM •
Sony VAIO...
Answered
on Oct 30, 2012
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off.
These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
