20 Most Recent
Philips CDR795 2-Disc CD Recorder Questions & Answers
Philips CDR 795 Power Supply Problem
I don't know what you are using to check the caps but in order to find the culprits, it's almost mandatory to have an instrument that will measure both capacitance and dissipation factor (DF) since that is what is killing most of our modern electronics.
If you don't find any caps pregnant or leaking deposits and plan on shotgunning it, I'd start with those with values between 4.7 & 100uFd as these are the most common failures and mostly in feedback paths and are lower voltages.
You can buy them at Mouser Electronics with no minimum charge and 'at cost' shipping.
Good luck-
Spindle motor
The Philips parts network may be in tattered condition currently because of their abandonment of the US market, turning over everything to Funai, a Japanese maker of miserable junk.
Philips/Funai
Philips CDR796 CD Recorder
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
LG DR6921W
Unplug the power cord, then hold the fast forward and fast reverse while plugging the power cord.
Recording to cd
Disc recover occurs when the power goes off and comes back on halfway through a disc being recorded. Try a new disc? You may have a faulty PCB on the record side.
Trays locked
remove the tray out & put the grease on gears under the tray
