20 Most Recent
Peavey PV6 Mixer Questions & Answers
How to connect a vocal processor to a peavey6 mixer
Set the voice input level on the voicelive2 by following this guide from the live 2 manual...
Step 4: Set Mic Level
This step informs VoiceLive 2 how loud you plan to
sing with your particular mic. We'll use VoiceLive 2's
automatic MIC GAIN feature to quickly set the optimum
level.
1. Press and hold the REVERB footswitch
2. If you need to activate phantom power for your
condenser mic, adjust the onscreen PHANTOM
parameter which will restart the level test
2. Sing for five seconds with peaks that are as loud as
you plan to sing
3. Follow the prompts in the display to finalize mic
level setting, cancel or redo the procedure
During performance, if you see the CLIP indicator light
in the HOME screen, you can return to the automatic
MIC GAIN feature to adjust the input level.
When input level is set on the voice live ;
on the mixer set the gain control to 12 o'clock position and
individual channel volume level to 7 ....raise the master volume
slider to hear mic input at desired level and without feedback
High pitch feedback
you are sending the signal back on itself, hit the usb to main switch to off.
How to install into pedal chain to input on amp
This mixer does not have inserts on the channels which you would normally use. Instead it has a single effects send and return, you set hw much is sent and returned on a per channel basis but unfortunately are stuck with just the one effects chain for all inputs.
If this is all you need then fine, you can apply your effects chain to all the inputs by as much or as little you want, this may work for echo and reverb on vocals or a single guitar on one input but for anything beyond this you are better off getting a decent mixer with proper inserts on all channels as well as sub and master inserts.
Clip is on as soon as I turn power on.
Sometimes this may be a result of a subsonic or supersonic signal, if it still does it with nothing at all plugged in and the FX turned right down there is a fault with your mixer.
Problems
This may be an issue with your power supply regulation, check opamp's ic's for +15V at pin-8 and -15V at pin-4, this may help to troubleshoot the issue.
How to get efx to work
You are aware that there are no built in effects, correct? Are you connecting an off board effects unit and having problems with that? You should be connecting the effects send on this mixer to the input of the effects unit - then the output of the effects unit to the effects return on the mixer. With the effects send control on the appropriate channel turned up, you should see signal hitting the effects unit. You'll need to adjust the effects return on the mixer to hear the effects signal included in your mixer output.
I have purchased a peavey
You MUST turn off the echo from the computer OR remove the sound card to line in connections. The tape out goes through the sound card and immediately back out to the tape in and around it goes for feedback.
Peavey 14 bt mixer won't pan. Keeps sending signal to both outputs
If your Peavey 14 BT mixer is not allowing you to pan the audio signal and is sending the same signal to both outputs, there could be a few potential reasons for this issue. Here are some troubleshooting steps you can take to address the problem:
1. **Check the Pan Controls:** Make sure you're using the correct pan controls for the channels you're trying to pan. The pan controls are typically knobs labeled "Pan" or "Balance" on each channel strip. Ensure that they're set to the desired positions.
2. **Reset Pan Controls:** If you've already adjusted the pan controls and they're not working as expected, try resetting them to their center positions. This can help eliminate any accidental settings that might be causing the issue.
3. **Channel Routing:** Some mixers have routing options that can affect panning. Check if there are any routing switches or buttons that might be affecting the signal routing for each channel.
4. **Mono/Stereo Mode:** Some mixers have a mono/stereo mode switch that can affect panning. Make sure the mixer is in the appropriate mode for your setup.
5. **Master Pan Control:** Ensure that the master stereo output pan control is set to the center position. If it's panned to one side, it can affect the overall stereo output.
6. **Test Different Channels:** Try panning different channels to see if the issue is specific to one channel or affecting multiple channels.
7. **Firmware/Software Update:** If your mixer has digital components or software control, check if there are any firmware updates available. Sometimes, software updates can address functionality issues.
8. **Physical Damage or Wear:** Inspect the pan controls and associated circuitry for any physical damage or wear that could be causing the issue.
9. **Factory Reset:** If none of the above steps resolve the issue, you might consider performing a factory reset on the mixer. Be sure to back up any important settings before doing this.
10. **Professional Service:** If the problem persists after trying these steps, it might be a more complex internal issue that requires professional servicing. Contact Peavey's customer support or a qualified audio technician for further assistance.
Remember that the exact steps and controls can vary depending on the model of your Peavey mixer. Refer to the user manual for your specific model for more detailed information on troubleshooting and operation.
8/20/2023 2:15:59 PM •
Peavey Music
Answered
on Aug 20, 2023
Does the peavey xr-600b have phantom power
It does not have built-in phantom power. Phantom power is a method used to provide power to condenser microphones and other devices that require a small amount of power to operate.
It is important to note that the XR-600B have XLR inputs which are typically used for condenser microphones that require phantom power but it does not provide this feature. If you want to use a condenser microphone with the XR-600B, you'll need an external phantom power supply or an audio interface that provides phantom power.
1/12/2023 8:34:18 PM •
Peavey Music
Answered
on Jan 12, 2023
Peavey bass R1080052 looking for any info .
Peavey R1080052 is a bass guitar model produced by the Peavey company. It is part of the company's Classic series of instruments, which are designed to offer vintage-inspired tones and aesthetics at an affordable price. The R1080052 features a solid ash body, a maple neck with a rosewood fingerboard, and two single-coil pickups. It also has a vintage-style bridge and a set of open-gear tuners. This bass is known for its warm, punchy sound and comfortable, easy-to-play feel.
1/10/2023 12:11:58 AM •
Peavey Music
Answered
on Jan 10, 2023
