20 Most Recent Peavey SP2 PA Passive Speaker Questions & Answers
2answers
Peavey sp2xt speakers horn makes no sound when plugged into normal input. Horn works fine when plugged into the high side of the crossover.
High side speaker input jack defective, as they are switch also and if you plug the wire from the amp in full range and no hf sound but connecting directly to the bi-amp hi does, then your female 1/4 plug at crossover is defective for sure.
5/18/2015 1:04:07 PM • Peavey SP2 PA... • Answered on May 18, 2015
Schematic soundguard
Blown poly switches????
9/20/2014 5:01:52 AM • Peavey SP2 PA... • Answered on Sep 20, 2014
Horns dont work on both sp2 ti
diaphrams, the high input is a direct connection the the horn.
9/20/2014 4:33:50 AM • Peavey SP2 PA... • Answered on Sep 20, 2014
Is there a fuse in a peavey sp2 for horns
there are 2 of them in the new ones....but ya probably the blew diaphrams...unless they are old one...then it could still be in the crossover..need to know the exact SP2 model you have, as they have changed the speaker again and again over the years.
9/20/2014 4:33:14 AM • Peavey SP2 PA... • Answered on Sep 20, 2014
What is the simplest way to connect speaker to radio?
Hi Micah, What Amp and leads do you have? Your passive speaker will need to be plugged into your amp speaker outs , and you radio into your Amps Tuner/Radio input or Aux, but just depends what system you have. Check what inputs and outputs your amp has and what leads you need as a lot of systems need different setup and cables/leads.
5/20/2014 3:22:28 PM • Peavey SP2 PA... • Answered on May 20, 2014
Which wire yellow or blue goes on red post
Peavey color indicates that Blue is Negative And Yellow Is Positive, so Yellow goes to + Speaker Terminal.
11/6/2013 11:47:52 PM • Peavey SP2 PA... • Answered on Nov 06, 2013
Hi,I have 2 sp2 cabs,getting sound thru the horn but none to the speaker,any ideas ? thanks
2 possibilities here:*Speaker coils got fried or,*Input jack named "Low" in the Bi-Amp section has a loose contact, as they are switch also.Hope this helps.
11/6/2013 11:43:06 PM • Peavey SP2 PA... • Answered on Nov 06, 2013
Peavey sp2 pa speakers quit working
Ok,First of all i need some more information, such the power amp you've hooked to them rating in watts and please specify if you are not getting sound from tweeter or 15" BW speaker or both of them, this way i can improve accuracy helping you out.
11/6/2013 11:40:06 PM • Peavey SP2 PA... • Answered on Nov 06, 2013
Hi,i got the circuit diagram of the soundguard
For the MOST PART the lamp is NOT the primary path for the speaker current, the POLYFUSE is and is a low resistance until it is overdriven.
The bulb is a 12 volt bulb and is nominally 2.1 amps when used on 12.8 volts.
If this is in regards to the other problem mentioning 32 watts and 12.8 volts... this bulb is NOT 32 Watts, it is 32 CP or 32 Candlepower which is NOT Watts in general. The lamp is actually around 27 Watts when run at its ratings.
It is important to realize that the lamp and the resistor are there ONLY as a "soft" path when the POLYFUSE opens due to overcurrent. When the polyfuse cools, the lamp and resistors are effectively shorted by the Polyfuse and most of the current again flows through the polyfuse..
2/15/2013 9:39:26 AM • Peavey SP2 PA... • Answered on Feb 15, 2013
2answers
Whats the wattage of the bulb used in peavey sp2
The lamp is an "1156" lamp... replace with that part number. Here :
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=524517&k=lamp%201156
Or you can find it at auto parts store.
LIKELY the polyfuse device is ALSO gone... Probably similar to this one (1.1 amp, trip 2.2 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2010-ND
or this one (1.85 amp, trip 3.7 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2013-ND
11/23/2012 2:45:14 PM • Peavey SP2 PA... • Answered on Nov 23, 2012
I just purchased 2 old
These cabinets are self contained and you do not use a crossover with them. The speakers do NOT come out to separate connectors. You just drive these with an amplifier. DO PAY ATTENTION to the power rating... you are safe using an amplifier with a MAXIMUM of 150 Watts RMS per speaker cabinet. More than that and running them loud and you will be replacing the speakers. These will cover a 40 foot square room at comfortable level.
8/16/2011 3:31:50 PM • Peavey SP2 PA... • Answered on Aug 16, 2011
I have a pair of SP2XT speakers. The woofer works
Hi budprice54,
High chance that both of them was blown due to high frequency signal from the amplifier. You may confirmed it by swapping with a working one or if not available test the incoming audio from the two speaker wire connected to this speaker with a multimeter set in AC. There was a small flactuating voltages reading depends upon the beat of the sounds if the audio signal was present.
If confirmed that the speaker was already faulty, there some shop specialized in speaker rewinding, this speakers need to replace the voice coil to work again or you may replaced it with a new one.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
4/6/2011 1:13:05 PM • Peavey SP2 PA... • Answered on Apr 06, 2011
Please, send me a circuit diagram of QSC(RMX 2450)
hi,
its with me. if u need the same contact me on my mail.
[email protected]
ok
1/28/2011 7:07:53 AM • Peavey SP2 PA... • Answered on Jan 28, 2011
So the wattage of the is 32 watts and voltage is
This makes no sense... 32 Watts and 12.8 volts... something to do with this speaker that is rated at 500 Watts???
If you are trying to calculate something for a car amp you don't understand how they work... that is the only thing I can think given the 12.8 volt thing you stated. Most high power car amps BOOST the incoming battery voltage up with a switching power supply. For instance, they might boost to 48 volts and that applied to a 4 ohm speaker would be 12 amps PEAK maximums. BUT the RMS power is one half that or about 288 Watts in round figures before considering losses.
Many car amps are designed to run with 2 ohm speakers... JUST SO THEY CAN CLAIM massive power values in their ads so you will buy them!
1/22/2011 2:26:31 AM • Peavey SP2 PA... • Answered on Jan 22, 2011
Could u please send me a circuit diagram of Peavey
Here is a link to forum that someone has posted the soundguard protection circuit down the page:
http://forums.peavey.com/viewtopic.php?f=26&t=2168&view=previous
The 1156 lamp MAY have slightly different shapes but is an automotive lamp. If the bulb is blown, the polyswitch fuse is likely blown as well.
1/14/2011 5:07:54 PM • Peavey SP2 PA... • Answered on Jan 14, 2011
Need a capasitor for crossover
Find them at Digikey.com. Search first for "Capacitor" then select "Non-Polar"
HOWEVER there is a part that LOOKS like a ceramic capacitor but it is NOT. It is a "polyswitch" which is a resettable fuse. Go to the Digikey.com site and search for "Polyswitch". Then select 60 volt in the filter and Radial... see if you can find the item. Also consider opening a second speaker if you have it to get the number off one that is still OK. This is part of a protection circuit and needs to be replaced with exact device.
12/29/2010 9:25:12 PM • Peavey SP2 PA... • Answered on Dec 29, 2010
No sound in horn when
The question is whether or not you get any sound from the horn when in full-range. If so, then either the input jack for the horn is defective, or you are not passing the signal. A quick check would be to send the full-range signal (at low volume) to the high-freq input. You should hear the horn work. If not then the connector is defective on the crossover board.
If you get no sound from the horn in any configuration, then the coil is blown for the horn. This can be replaced. It is usually a 22a or 22ti diaphram
Let us know what you find.
Dan
12/9/2010 1:23:12 PM • Peavey SP2 PA... • Answered on Dec 09, 2010
I have the Peavey PV14 mixer, and suddenly the effects will not work. It is not a new board but I have always taken really good care of it! Help!
It sounds like there might be an issue with your audio equipment or settings. Double-check the connections, ensure proper device selection, and verify if your equipment is functioning correctly. If the problem persists, consider seeking technical support or consulting forums for specific troubleshooting advice based on your setup.
1/3/2024 2:06:47 AM • Peavey Music • Answered on Jan 03, 2024
Peavey SP2 PA Passive Speaker Logo
29 questions posted
Top Peavey Music Experts
NOEL
NOEL
Ngoro
Are you a Peavey Music Expert? Answer questions, earn points and help others
View Most Popular
Peavey Music
  • Peavey Music
Most Popular Question
please send me circuit diagram qsc rmx
  • Music
