20 Most Recent
Roland RMP-5 Rhythm Coach Questions & Answers
I have a RMP-5 Rhythm Coach. I cannot get any sound from the pad when I practice. Help
Hi, after doing a bit of googling it occurs to me that the internal speaker is ONLY for the metronome / click & not for the drum sounds themselves. You will need headphones or some external audio gear like your hi-fi system or oth r amp & speaker. I found this "The pad has 54 sounds in it (covering all parts of the drum kit but mostly snares), which are triggered when you hit the mesh head, but these can only be heard over headphones. The built in speaker is only used by the metronome sound (when there are no headphones attached) and then it only has a beep sound attached to it. However, plug in headphones and you get a variety of available click sounds including a proper ticking clockwork metronome." Hope that helps a little? Good Luck :-)
Hi. Can I use the second pedal on my Roland BK5 to scale up the key one semitone at a time?
Yes, you can use the second pedal on a Roland BK-5 keyboard to transpose the key of the music that you are playing up or down by a semitone at a time. To do this, you will need to press and hold the second pedal while playing the keyboard. You can also use the transpose function in the settings menu of the BK-5 to adjust the key of the music that you are playing by a specific number of semitones.
1/5/2023 4:04:49 PM •
Roland Music
Answered
on Jan 05, 2023
I need a circuit diagram for a Roland MA-15D speaker please?
It's a Chinese made Roland and no service information is available as when a fault is found the main board is replaced, eliminating the need for service information.
I would check that it is a stereo out jack and not mono. If it is a stereo out, check that both input phonos work. If they do, replace the faulty socket or damaged pcboard.
11/17/2022 6:14:26 PM •
Roland Music
Answered
on Nov 17, 2022
MY Roland Handsonic's digital display is gone
Hell,
there is no display on your Roland Handsonic because the screen inverter or screen board panel is faulty. This has to be replaced for you to see your digital display again.
So its either you use it like that without the display or you take it to a repairer for fixing.
Take care.
7/11/2022 8:54:01 AM •
Roland Music
Answered
on Jul 11, 2022
