20 Most Recent RCA F36668 36" TV Questions & Answers
Menu screen comes on the screen with out me touching the remote. The remote only can turn the tv on and off, nothing else.
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean. http://remotesearch.blogspot.com/ Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
1/20/2016 3:11:17 AM • RCA F36668 36"... • Answered on Jan 20, 2016
RCA MODEL# F36668 TV, 36" OR 37"
If you feel comfortable taking the cover off the back, check the fuse that should be soldered into the board, near the power cable/etc.  If you do not feel comfortable doing that, then you should have a repair shop take a look at it.  It might be a cheaper fix than you think.
9/16/2014 1:16:12 AM • RCA F36668 36"... • Answered on Sep 16, 2014
Manuals owners
11/4/2013 2:07:54 PM • RCA F36668 36"... • Answered on Nov 04, 2013
Can't find a service manual for an RCA f36668
Send your email address to me by Fixya, and get back a copy of it by return mail.
12/27/2012 6:26:21 PM • RCA F36668 36"... • Answered on Dec 27, 2012
PICTURE IS TOO WIDE FOR SCREEN. SOME OF THE SPORTS
Hello
If the picture is too wide, both in vertical and horizontal direction your TV needs power supply adjustments. It is now running at overvoltage, and this condition may poise to another problems soon. Get it repaired soon. Its internal regulated voltage needs to be adjusted. You cannot do it by yourself. Get it repaired by the help of a technician. Don't switch on the TV till its fault have got rectified.
10/18/2010 8:46:03 AM • RCA F36668 36"... • Answered on Oct 18, 2010
Can I get a replacement remote?
try their website
6/12/2010 9:36:25 PM • RCA F36668 36"... • Answered on Jun 12, 2010
NO COLOR IN MY RCA F36668 TV
Could be a bad TV or it could be loose TV connections feeding to the back of the TV. Any poor or loose connections in the cable leads causes a loss of signal strength to the TV.
Old cables and connection supplying TV Cable to the house or apartment can cause this problem also.
8/15/2009 11:58:45 PM • RCA F36668 36"... • Answered on Aug 15, 2009
Rolling lines on screen
Sounds like the power supply has a bad capacitor. This problem can inject excessive 60 hz from the AC line into the vertical stabilizing picture system. The hum also my come from the same reason, bad or leaking filter capacitors. Cheaper just to buy a new TV or borrow another TV and connected to your system to see if the problem still occurs.
8/15/2009 11:51:15 PM • RCA F36668 36"... • Answered on Aug 15, 2009
2answers
I just got a rca tv mdl# f36668 36
the easy way is to buy a universal remote
the cost is around 8-10 dollars
8/15/2009 11:43:56 PM • RCA F36668 36"... • Answered on Aug 15, 2009
I have scrolling horizontal lines on both tv sets
Sound s like a powerpack issue poor smoothing or regulator trouble
7/7/2009 10:50:25 PM • RCA F36668 36"... • Answered on Jul 07, 2009
I have 3 RCA TVs
Maybe the tv is to old I have a rc tv to but no cable you could get a new tv I guess not to sure maybe your anntane [an-tan-a] is broke if you have one
hope this helps
6/27/2009 9:13:18 PM • RCA F36668 36"... • Answered on Jun 27, 2009
RCA tv with guide plus comes on and off randomly
these tv's are bad for caps in power supply, fluctuations freaking your micro.
5/13/2009 12:53:12 PM • RCA F36668 36"... • Answered on May 13, 2009
2answers
TV turns off by itself, juggling power cord causes TV to come back on
It could seem to be a power cord problem But when you move around the cord you are realisticly flexing the printed circuit board assy. If you know all the safety issues around the servicing a solid state tv, then Of course I will assit you, in any way I can, But you must be aware of the high voltage that these sets store , even if they Are unplugged. Its a total safety issue. If you have no experience using a multi- meter as well as the safety issue awarness, then PLEASE seek a pro to assist you with this reapir, as it will get worse in the long run and cost ya more to fix, as everytime you move around the cord and the set shuts off, then goes on , your surging the componets!. Good Luck
10/20/2008 7:43:25 PM • RCA F36668 36"... • Answered on Oct 20, 2008
Channel's going Crazy
You could have dirty contact switches on Front panel board the one with power vol+ vol- ch + ch- remove the board clean with contact cleaner this shoud slove your problem if not replace front panel board.
9/26/2008 10:42:15 AM • RCA F36668 36"... • Answered on Sep 26, 2008
Color is all red - picture hard to see
Bought a new TV since it wasn't worth it to fix the old one.
8/31/2008 8:07:01 PM • RCA F36668 36"... • Answered on Aug 31, 2008
TV clicks/snaps and won't turn on
Did they say for sure what parts are bad? My guess flyback transfomer/ shorted hori output transistor NTE2324.And to answer your other question about you trying to fix this keep in mind this set carrys up to 36,000 volts and if you really dont know what you are doing can get you killed.leave it to the PRO's to fix unless you have at lease 3yrs of Electronics.
8/28/2008 11:59:50 PM • RCA F36668 36"... • Answered on Aug 28, 2008
Fuzzy picture
resolder grounds around tuner.
8/19/2008 10:19:44 PM • RCA F36668 36"... • Answered on Aug 19, 2008
Response to solution
Labor 125.00 parts FBT 89.00 hori 19.95
5/2/2008 6:04:18 PM • RCA F36668 36"... • Answered on May 02, 2008
TV turns on & off by itself. Channels also change by themselves.
Make sure your remote is totally away from the set.
Make sure the buttons on the set are not sticky
If both of those are ok, it's your E-Prom in the set. RCA's are notorious for this, not a major repair, maybe $75-100. The 8 leg e-rom is only about $6.00
4/30/2008 8:02:11 PM • RCA F36668 36"... • Answered on Apr 30, 2008
RCA F36668 36" TV Logo
38 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
39 t find service manual rca f36668
  • Televison & Video
