20 Most Recent
Ricoh Aficio SP4210N Laser Printer Monochrome - 37 ppm Mono - 1200 x 600 dpi - USB, Network - Fast Ethernet - PC, Mac Questions & Answers
I have Ricoh Aficio MP c2800, Machine say toner undetectable all four when i check system status and yellow, cyan is not show up on copies at all
If your Ricoh Aficio MP C2800 is showing "toner undetectable" messages for all four toner cartridges and the yellow and cyan colors are not showing up in copies, there may be several potential causes for this issue. Here are some troubleshooting steps to help you resolve the problem:
- Check Toner Cartridges: Ensure that all four toner cartridges are correctly installed and securely seated in their respective slots. Make sure there are no protective seals or tapes left on the cartridges.
- Shake Toner Cartridges: Sometimes, toner inside the cartridges can settle or clump, leading to detection issues. Gently shake each toner cartridge side to side to redistribute the toner evenly.
- Replace Toner Cartridges: If the toner cartridges are old, empty, or expired, replace them with new, genuine Ricoh toner cartridges.
- Clean Contacts: Dust or debris on the toner cartridge contacts can interfere with communication. Use a soft, lint-free cloth to clean the electrical contacts on both the toner cartridges and inside the printer.
- Check Developer Unit: The developer unit in the printer plays a crucial role in toner development and transfer. Ensure that the developer unit is clean and free from any obstructions.
- Perform a Firmware Update: Check if there are any firmware updates available for your Ricoh MP C2800 printer. Updating the firmware might address known issues and improve printer performance.
- Reset the Printer: Power off the printer, unplug it from the power source, wait for a few minutes, and then plug it back in. Power the printer on to see if the issue resolves.
- Check Toner Detection Sensors: The printer uses sensors to detect the presence of toner cartridges. Verify that these sensors are functioning correctly and not blocked by any debris.
- Perform a Factory Reset: As a last resort, you can try performing a factory reset on the printer. However, be aware that this will reset all settings to their defaults, and any custom configurations will be lost
Code error SC545 Ricoh SP210su
I had the same problem, but solved it.You have to connect your printer SP210 to your computer.Search (in Windows) "Smart Organising Monitor Status"Select Printer (new dialog box)Click OK (see the error code SC545)Click on User ToolsPrinter Configuration(Access Code is Admin074)Find Fuser SC Reset under MaintananceClick OkCloseRestart your printerYour problem is solved nowORWithout connecting your printer to Computer (you can do this):Turn on the printerPress C (Red colour centre) button onceEnter 107 (nothing will be shown)Press the Green (Coping) button for 5 secondsSee the Display -->Select Engine MaintenanceSelect OkSelect Fuse SC Reset (press down arrow - at down you will find it)Execute (by Pressing the Down Arrow)DoneRestart your printer.Your problem should be solved....
