20 Most Recent LG LN5100 50" LED TV 1920x1080, 60 Hz, HDTV Questions & Answers
Lg led tv has sound but no picture
Unless you have a friend that fixes these flat screen cheap I would just replace it, I see so many stories about attempted repairs $100's spent and still the TV is not fixed. The new models are cheap and most are better than ever.
9/7/2016 9:59:51 PM • LG LN5100 50"... • Answered on Sep 07, 2016
How do I fix a LED television that goes in and out of focus?
Sounds like a cable vision problem. I had the some issue and the cable guy replaced the box and that fixed it. I would also check all your cable connections first. If you don't have cable I don't know what to tell you.
4/9/2016 6:44:03 PM • LG LN5100 50"... • Answered on Apr 09, 2016
Hi I have a TV that have no image but I can hear the sound when I adjust the volume and switching the channel. I assume it may be the backlight failure after doing some research online.
I would call LG tech support and ask them which of your boards has the circuits normally contained on the inverter board. You are on the right track.
3/27/2016 6:25:17 PM • LG LN5100 50"... • Answered on Mar 27, 2016
0answers
2answers
No power, no picture just a red light stays on for 20 second
Good Luck.
10/22/2015 9:13:12 AM • LG LN5100 50"... • Answered on Oct 22, 2015
2answers
The picture on my LED TV went out abruptly and wont come back on. I'm getting sound, but no picture, besides replacing the LED driver/power board (I did), what can be done to fix it?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions. Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
3/25/2015 7:31:03 PM • LG LN5100 50"... • Answered on Mar 25, 2015
I have a LG dvd player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning. Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem. Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates. Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV. The hum is simply the player trying to read the disc. It can't so, it spits it out. Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
4/19/2024 8:46:44 PM • LG Televison &... • Answered on Apr 19, 2024
3answers
Fuse diagram for a LG plasma model pdp42v80201
The screen blank out
4/7/2024 11:03:07 PM • LG Televison &... • Answered on Apr 07, 2024
LG Plasma TV is not displaying picture when it is turned on
This is the Power Board for it. check those 6 electrolytic Capacitors on the right for bulging or splitting. Don't buy it blindly, it's a guess. The output voltages with a digital multimeter. https://applianceparts.com/item/10217204/LG/EAY62812602/ Many parts are obsolete. eBay has used boards, but they are risky because they are out of scrapped sets. https://www.google.com/search?q=50PN5300-UF+power+board We have a television expert named Larry, but I haven't seen him for a while. This used to be my advice https://www.fixya.com/support/r29790007-repairing_own_television ..
3/30/2024 8:59:29 PM • LG Televison &... • Answered on Mar 30, 2024
3answers
DVD reading problem on a LG DVD5083 DVD player.
Maybe the disk is not compatible with the DVD player version
3/24/2024 9:16:41 AM • LG Televison &... • Answered on Mar 24, 2024
How do I program my DVD video remote control to my LG Blu Ray surround sound player please?
It can't be done. The DVD remote will be single frequency for that device only and the LG remote for that LG Blu Ray (or series) only. Companies don't make cross-control between makers easy. The only exception is cable and satellite boxes to allow their remote to also control the television. If you have lost a remote or it doesn't work, this is the answer https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
3/19/2024 4:25:52 PM • LG Televison &... • Answered on Mar 19, 2024
LG BD590 250 GB HD Network Blu-ray Disc Player. How to make LG BD590 region free?
Question edited for a lot more clarity. All in the link https://www.google.com/search?q=LG+BD590+make+region+free ..
3/17/2024 3:28:16 AM • LG Televison &... • Answered on Mar 17, 2024
How can I program my LG DVD remote control COV33662806 to my LG 55 Roku television.
You can't, the LG DVD Remote is single frequency. If you are lucky, the LG Television Remote, might control an LG DVD. If you have lost a remote, have a read of this https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
3/15/2024 11:09:16 PM • LG Televison &... • Answered on Mar 15, 2024
Could you help diagnose the issue with my LG TV MODEL 65UN7300AUD that does not power on?
If you would like to share any clues, yes. Checked power going in, I presume. Any indicator lights? If yes, how many times does it flash?
3/15/2024 7:15:50 AM • LG Televison &... • Answered on Mar 15, 2024
2answers
My LG DVD/CD receiver Model:LH-D6246,Shows disc 'error' when I load a dvd or cd disc but the radio plays very well please help
faulty dvd reading lens,should be change by expert professional
3/14/2024 12:44:09 AM • LG Televison &... • Answered on Mar 14, 2024
How to activate universal remote control AMELY AD-UL101S with LG TV Brand or other brand?
Question edited for clarity and add maker. No one uses Universal Remotes these day. You buy a Remote that is a Copy of the original. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote The AMELY is a very cheap and nasty Chinese Remote and they don't supply instructions!! https://www.amely.cn/AD-UL101-S-AMELY-unviersal-TV-LCD-LED-remote-control-p636185.html Codes are decided by the brand of television. This is for LG https://www.google.com/search?q=universal+remote+codes+for+lg+tv ..
3/3/2024 4:57:30 PM • LG Televison &... • Answered on Mar 03, 2024
LG DVD Player - DSI-8555 manual please?
It appears to be a model made for the India market. https://www.google.com/search?q=lg+dsi+8555+manual This is the only service manual that is related. If the display is not working, look on the back of the display board for a split or bulging electrolytic capacitor.
SERVICE MANUAL
Encompass Parts https://research.encompass.com > ZEN PDF This manual was prepared for use only by properly trained audio-video service technicians. When servicing this product, under no circumstances should the ... 109 pages
3/2/2024 7:45:46 PM • LG Televison &... • Answered on Mar 02, 2024
LG LN5100 50" LED TV 1920x1080, 60 Hz, HDTV Logo
7 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
lg led tv sound but no picture
  • Televison & Video
