20 Most Recent Kocaso M766 Dual Core 1.5Ghz Dual Camera Android 4.2 Capacitive Tablet PC Black Questions & Answers
Model 766 will not take a charge
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. Support Troubleshooting Guide
3/15/2015 10:18:06 PM • Kocaso M766 Dual... • Answered on Mar 15, 2015
Kocaso m766 cannot charge
You have damaged the USB socket in some way.
2/22/2015 10:50:39 PM • Kocaso M766 Dual... • Answered on Feb 22, 2015
M766 comes up to the Kocaso screen and won't go any further have tried reset and also recovery, and it does not help. What can I do?
Have you tried re-loading the firmware? Here is the page with instructions, and the firmware for your tablet. Support Firmware
2/22/2015 10:08:06 PM • Kocaso M766 Dual... • Answered on Feb 22, 2015
Touch screen is not working properly
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. This should reset the calibrations to default. http://www.kocaso.com/troubleshooting.html
2/22/2015 9:13:37 PM • Kocaso M766 Dual... • Answered on Feb 22, 2015
Cracked screen
The manufacturer does not cover accidental damage, but they do instituted a program where you can turn your tablet with a cracked screen in (as long as you are still within your warranty period. The nice thing about this is that not only they use the least expensive route when you crack your screen, but you do not have to wait for repairs. They simply send a replacement once the company receive your damaged one. Contact the company at Company Contact us to setup your request.
2/22/2015 8:22:58 PM • Kocaso M766 Dual... • Answered on Feb 22, 2015
Has green, blue and yellow lines on a white screen
The nice thing about this is that not only are they the least expensive route when you repair your screen, but you do not have to wait for repairs. They simply send a replacement once they receive your damaged one. Contact them to setup your request at http://www.kocaso.com/contact_us.html
2/22/2015 6:58:49 PM • Kocaso M766 Dual... • Answered on Feb 22, 2015
Cracked screen kocaso M766 don't unlock,
The manufacturer does not cover accidental damage, but we instituted a program where you can turn your tablet with a cracked screen in (as long as you are still within your warranty period. The nice thing about this is that not only are we the least expensive route when you crack your screen, but you do not have to wait for repairs. We simply send a replacement once we receive your damaged one. Contact us at Company Contact us to setup your request.
2/22/2015 6:43:42 PM • Kocaso M766 Dual... • Answered on Feb 22, 2015
CANT CHARGE KOCASO M9200
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on. If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on. Support Troubleshooting Guide
2/22/2015 5:00:44 PM • Kocaso M766 Dual... • Answered on Feb 22, 2015
Need to know how to do a hard reset
You can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. Support Troubleshooting Guide
2/21/2015 8:49:40 AM • Kocaso M766 Dual... • Answered on Feb 21, 2015
How to change the pattern passcode on a m766 kocaso tablet?
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings. Support Troubleshooting Guide
2/21/2015 8:41:44 AM • Kocaso M766 Dual... • Answered on Feb 21, 2015
How do I get the firmware for a kocaso m766 tablet?
http://www.kocaso.com/support.html. firmware is available , sometimes there's more then 1 model,, I have the 1066 and there are 5 different 1066's (a, b, c, d, e) so check well
9/30/2014 3:26:25 AM • Kocaso M766 Dual... • Answered on Sep 30, 2014
My android 4.2 tablet unbootable
Try pushing the reset button in the TINY hole in the back of the tablet.
1/11/2014 3:13:43 AM • Kocaso M766 Dual... • Answered on Jan 11, 2014
Call Customer Service Number Call 1-805-225-6690 We are 24 Hour Available Call Now For help
Factory reset it or go into settings accounts and delete the gmail account, and google account.
11/6/2019 8:42:20 AM • Kocaso Tablets &... • Answered on Nov 06, 2019
Tablet stuck at boot up' android screen wont go away
5/3/2015 3:54:24 PM • Kocaso Tablets &... • Answered on May 03, 2015
It won't unlock i can't open the tablet
3/28/2015 12:08:31 AM • Kocaso Tablets &... • Answered on Mar 28, 2015
Tablet will not turn on
3/15/2015 10:17:06 PM • Kocaso Tablets &... • Answered on Mar 15, 2015
Wireless keyboard wont connect
The tablet does not have capability to support a wireless keyboard, only a USB one or Bluetooth one.
3/15/2015 10:13:35 PM • Kocaso Tablets &... • Answered on Mar 15, 2015
Kocaso M766 Dual Core 1.5Ghz Dual Camera Android 4.2 Capacitive Tablet PC Black Logo
19 questions posted
Top Kocaso Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Kocaso Tablets & eReaders
Most Popular Question
get firmware kocaso m766 tablet
  • Tablets & eReaders
