20 Most Recent Kocaso M730W 1.2GHz 4GB 7 Capacitive Touchscreen Tablet Android 2.3 Questions & Answers
3answers
Son forgot password
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings. Support Troubleshooting Guide
11/23/2016 11:02:07 AM • Kocaso M730W... • Answered on Nov 23, 2016
Forgotten passcode can i do a factor reset or a hard reset
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
3/15/2015 9:52:53 PM • Kocaso M730W... • Answered on Mar 15, 2015
Can i charge my kocaso tablet wirelessly
No, the only to charge it is via the USB socket.
2/22/2015 11:12:34 PM • Kocaso M730W... • Answered on Feb 22, 2015
I cannot unlock my tablet from the touch screen
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. Support Troubleshooting Guide
2/22/2015 9:15:37 PM • Kocaso M730W... • Answered on Feb 22, 2015
Kocaso m736 connect to mobile network
Product spec says "Support external 3G module dongle". You need to find a compatible one, Kocaso don't do one. Put in a SIM card, pay for a Data connection, every 30 days. Set up the connection settings dependent on the SIM supplier. This depends on where you live in the world. Huawei E173 is the only one that someone has found to work on android tablet.
2/22/2015 9:01:12 PM • Kocaso M730W... • Answered on Feb 22, 2015
Need help in getting my KOCASO M736 working
2/22/2015 6:47:39 PM • Kocaso M730W... • Answered on Feb 22, 2015
Won't turn on
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on. If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on. Support Troubleshooting Guide
2/22/2015 6:46:14 PM • Kocaso M730W... • Answered on Feb 22, 2015
Unlock
The Lock symbol needs to moved to the right to the unlock symbol by your finger. This will then load the desktop and activate the touch screen. Support Troubleshooting Guide
2/22/2015 5:32:09 PM • Kocaso M730W... • Answered on Feb 22, 2015
Unlock a kocaso M736 tablet forgot google password
2/22/2015 5:28:51 PM • Kocaso M730W... • Answered on Feb 22, 2015
How do i unlock my new kocaso tablet
There is a circle on the screen in white. Drag it to the right, towards the unlock symbol which will appear on the screen. Read the manual. Support Manuals
2/21/2015 9:42:42 PM • Kocaso M730W... • Answered on Feb 21, 2015
Touch screen replacement
this may help https://www.youtube.com/watch?v=CKDeN0g0Rbk
9/3/2014 12:36:47 AM • Kocaso M730W... • Answered on Sep 03, 2014
The screen is not white after i opened it up it fell and was showing blurry
I would think that the mainboard or one of the aux circuit boards is damaged. Your tablet is broken. Buy another and don't drop it.
3/26/2014 9:16:42 PM • Kocaso M730W... • Answered on Mar 26, 2014
0answers
Factory reset
Be the first to answer 1/22/2014 1:23:24 AM • Kocaso M730W... • Posted on Jan 22, 2014Be the first to answer
Forget password tablet
Get PowerSuite: a Utility CD that can locate the Passwords. Then tell it to clean the Password section and that's it. Now the system opens like new.
12/22/2013 8:10:04 PM • Kocaso M730W... • Answered on Dec 22, 2013
I need to replace the internal battery
so what go in the mobile store..
11/5/2013 11:05:30 AM • Kocaso M730W... • Answered on Nov 05, 2013
I dont have my password
Try this::While the power is turned off hold the power button and up volume button by pressing them. Keep holding them until something appears on the screen. Then release and you should be given the option to erase all the data from the Kocaso tablet.
11/4/2013 12:28:32 AM • Kocaso M730W... • Answered on Nov 04, 2013
MY SON TRIED TO USED MY KOCASO AND HAS ENTERED
TRY:::While the power is turned off hold the power button and up volume button by pressing them. Keep holding them until something appears on the screen. Then release and you should be given the option to erase all the data from the Kocaso tablet.
11/4/2013 12:27:57 AM • Kocaso M730W... • Answered on Nov 04, 2013
2answers
How do i unlock my kocaso?
as unlocking my tablet m760s kocaso forget my password
4/21/2013 10:20:24 PM • Kocaso M730W... • Answered on Apr 21, 2013
Wifi doesn't connet
turn it off then back on
7/2/2012 5:34:27 PM • Kocaso M730W... • Answered on Jul 02, 2012
Kocaso M730W 1.2GHz 4GB 7 Capacitive Touchscreen Tablet Android 2.3 Logo
34 questions posted
Top Kocaso Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Kocaso Tablets & eReaders
Most Popular Question
unlock kocaso
  • Tablets & eReaders
